Page 8 of 74 FirstFirst ... 678910 ... LastLast
Results 71 to 80 of 734
Thread: Jay see 1997 GU build up
  1. #71
    Can anyone recommend a good tyre place that knows what they're doing.
    Go see Andrew @ On Track he works on Patrols every day of the week
    He even owned a 235 Rwkw comp truck Patrol of course.
    Very little he doesnt know about Patrols
  2. The Following User Says Thank You to threedogs For This Useful Post:
    jay see (10th January 2016)
  3. #72
    Cheers guys.
    The km2 M/T is what your talking about yeah?
    Ive heard good things from these, but what else do people run. Was thinking of coppers, but after BAs trouble maybe not. Federals, Mickey's anyone tried Achilles?
  4. #73
    Nittos or toyos.
  5. The Following User Says Thank You to nissannewby For This Useful Post:
  6. #74
    I'm pulling out the radiator next week to replace the top tank, while mucking around in the shed I found a couple of temp gauges.
    Problem is that I could only find one sender.
    I tried to test by running a wire from the gauge to the sender and dripping the sender in a pot of boiling water. Nothing.
    Is there any other way to test before I go and buy a new one.
  7. #75
    When putting in a top hose adapter for a temp gauge what is the best position to have the sender. Wouldn't it be more accurate if the sender was facing down.
    Would prefer to drill and tap into the housing, has any done this with a tb45?
    Can anyone tell me what is this, can it be removed?
  8. #76
    I know the td42 runs the temp sensor and the glow plug water temp from the thermostat housing, it's to shut the glows off once engine temp is up to a set amount..
    Does the tb have a "choke" on it?? Maybe a similar situation?
  9. The Following User Says Thank You to BigRAWesty For This Useful Post:
    jay see (18th January 2016)
  10. #77
    Cant you run an Ecu-Talk instead of running guages ??
  11. The Following User Says Thank You to threedogs For This Useful Post:
  12. #78
    I worked out that it's the ECU temp sender. Found a thread here from 2012.
    If not using gauges I would rather use something like this.
    http://www.nissandatascan.com/.
    Need to look into it a bit more.
    Still would like to know where ppl have drill and tapped into the thermostat housing, or if they run the adapter with the sender facing down.
  13. #79
    Would this work. Can run both factory and aftermarket sender, both before the thermostat.
    http://www.ebay.com.au/itm/321947356...%3AMEBIDX%3AIT
    Would there be enough room for the coolant to freely move around?
  14. #80
    Patrol Guru Kimbo63's Avatar
    Dec 2015
    Perth WA
    5 Post(s)
    There will be no problem fitting a tee I done it for my oil pressure gauge as well go check your local hosemasters,pertek or Enzed
  15. The Following User Says Thank You to Kimbo63 For This Useful Post:
