FYI if your having trouble with your squirters no squirting water in the right spot,,,,?
Go grab a sewing needle [small] insert it into the squirter jet and move till you get the
right angle,
Also sometimes small peebles will get trapped behind the squirter,,,so just remove the clear tubing from behind
and that should clear them, its a good idea to push the needle into all the holes as sometimes mud partially blocks them.
Its the same for the rear one as well
