Page 5 of 5 FirstFirst ... 345
Results 41 to 48 of 48
Thread: Usb charger to fit rocker switch slot
  1. #41
    Well here ya go another option that I have just come across on fb..
    It seems both ports on this one are 3A.. which is a bonus..
    I reckon that'll be one 2.1A port and one 1A port.
  2. #42
    Your thinking 3 total. I shall enquire..
    Yeah that's how the sneaky buggers usually advertise them
  4. The Following 2 Users Say Thank You to Winnie For This Useful Post:
    Bacho86 (29th October 2015), BigRAWesty (29th October 2015)
  5. #44
    This mob sells different colour ones so you can match your head unit
    and other carling style rockers you may have
    http://www.ebay.com.au/itm/ScanGauge...UAAOSw~bFWMo7G
  6. The Following User Says Thank You to threedogs For This Useful Post:
    BigRAWesty (30th October 2015)
  7. #45
    I purchased and installed one of these a couple of months ago. They look great and work great - except that I thought that they were also an on/off switch so you could use the rocker to switch the USB charger on and off. They are not and as I connect every accessory to the auxillary battery, I had to install a separate switch. Otherwise the USB would be permanently on. Anyway, I don't like the idea of connecting the USB charger to the ignition switch because sometimes I want to charge things when the ignition is off.
    Yes was looking at that. But a simple relay from the ignition to ativate it would be the go..
    yep I reckon 3A total too, 3A when you have one phone being charged then maybe if your lucky splits to 1.5A each socket when charging 2 phones
  9. The Following User Says Thank You to Clunk For This Useful Post:
  10. #47
    Patrol Freak BillsGU's Avatar
    Jul 2010
    Thurgoona
    7 Post(s)
    Not needed. When you turn the key off - it goes off - which is what I don't actually want.
  11. The Following User Says Thank You to BillsGU For This Useful Post:
    BigRAWesty (31st October 2015)
  12. #48
    http://www.ebay.com.au/itm/371411135...%3AMEBIDX%3AIT
    Found some a bit cheaper, shop sells red, blue ,white and green switches
