Results 21 to 30 of 32
Thread: Thinking of making a rear tube bar for the GU....
  1. #21
    North brissy
    Use tube if you want it stronger not pipe.
  2. #22
    477 Post(s)
    Lol. Theres a difference? Goes to show how much i know.
    Having said that, would it be ok to weld on bends? Or use a bender?
  3. #23
    North brissy
    Yes there is. Tube is od. Pipe is id. Thickness with tube will be referred to as "schedule".
  4. The Following User Says Thank You to nissannewby For This Useful Post:
    BigRAWesty (22nd October 2015)
  5. #24
    North brissy
    Decent schedule tube cant be bent on a small bender though.
  6. #25
    477 Post(s)
    Ok so welding is fine. I can weld but i wont be welding i think. I will tack it all together when time comes to do this, but i will get my mate who welds for a living to do it for a neater finish.
  7. #26
    I used 40nb for the top rail of winch bar.. with 12mm side plates with the recovery points..
    I may or may not have nosed a stobie pole when chucking a u turn after first fitting it..
    The bar didn't Budge lol
    22 Post(s)
    Good tube is ideal, 40nb 3.2mm wall is cheap and can be bent in a small bender, just keep the seam on the inside of the bend where possible
    96 GQ coil/Cab
    08 G6eT
  9. The Following 2 Users Say Thank You to Ben-e-boy For This Useful Post:
    BigRAWesty (23rd October 2015), mudski (22nd October 2015)
  10. #28
    North brissy
    Yep and plenty strong. I just like to throw spanners around lol.
    Do something different and make it out of 6mm wall 6061 ally tube
  11. #29
    477 Post(s)
    Yep and plenty strong. I just like throw spanners around lol.
    Nows theres an idea. Only thing is ally tube would look crap on a white patrol i reckon. Unless i paint it. Steel is fine for me.
  12. #30
    North brissy
    And the price will scare you lol.
  13. The Following User Says Thank You to nissannewby For This Useful Post:
