Page 20 of 101 FirstFirst ... 1819202122 ... LastLast
Results 191 to 200 of 1003
Thread: Hodge's new 4.2
  1. #191
    Patrol Freak Bacho86's Avatar
    Mar 2011
    14 Post(s)
    Thanks folks, this morning it was freezing and I recorded it the second after start up. Will post it up later. You will hear exactly what I'm talking about.
    If your really concerned I'm happy to swap my CRD for your 4.2? ha ha ha
  2. The Following 3 Users Say Thank You to Bacho86 For This Useful Post:
    Bloodyaussie (22nd September 2015), Hodge (22nd September 2015), Woof (22nd September 2015)
  3. #192
    177 Post(s)
    lol
    No concerns here mate. I'm happy with it no matter how many clunks it makes....
  4. The Following User Says Thank You to Hodge For This Useful Post:
    Bacho86 (22nd September 2015)
  5. #193
    177 Post(s)
    So I've got all the bits to do my first oil, filters, fuel and air filters this weekend on the 4.2 . To some of you it's a breeze, to me it's a mission. lol
    Just realize I have to go and get one of them pump thingies for this 20L drum...
  6. The Following User Says Thank You to Hodge For This Useful Post:
    Rocket55 (24th September 2015)
  7. #194
    Patrol Guru Rocket55's Avatar
    Sydney
    3 Post(s)
    You'll be right mate, just take you time, there's no rush.
    Warm it up first, don't do it cold, it helps the oil run out better.
    Don't drop the sump plug into the catch container (remember the oil will be hot)
    Make sure your catch container has enough capacity!
    Take the oil filler cap off, helps it drain.
    Change your filters
    Put the sump plug back in - can't stress this enough haha
    Fill it back up with oil - I use a 1 liter oil container to measure it out.
    Fuel filter.
    Take the 2 fuel lines off
    Undo the 2 bolts and take the entire filter assembly off the car
    Unscrew the filter over a bucket to catch the fuel.
    Screw the new filter on
    Put the assembly back in the car
    Prime it up till it goes hard
    Start it up
    That's how I do it anyway.
    This is the oil drum pump I got, seems to work Ok.
    http://www.supercheapauto.com.au/onl...ecommendations
    Cheers Rod
    _______________________________________________
    Bitumen ...... Another watse of public funds
    My Build 2005 TD42TI
  8. The Following User Says Thank You to Rocket55 For This Useful Post:
    Hodge (25th September 2015)
  9. #195
    Thomastown, Melbourne
    6 Post(s)
    If ya get in trouble yell out Eric. ..
  10. The Following User Says Thank You to Bloodyaussie For This Useful Post:
  11. #196
    North brissy
    I will add to rockets response. Remove the fuel filter and filter head from bracket (dont forget to unplug water sensor). Then change the oil filters, much easier with the fuel filter out of the way.
    You can also flip the filter assembly over and put the bolts back as this will allow you to undo it easier. You can just crack it without losing fluid and making a mess then empty into said container.
    They take just over 11 litres.
    The spouts that come in those drums make them fairly easy to poor if you have a funnel that fits in the filler. Or just find an old jug in the house .
  12. The Following 2 Users Say Thank You to nissannewby For This Useful Post:
    Hodge (25th September 2015), Rocket55 (24th September 2015)
  13. #197
    Sydney
    3 Post(s)
    Some great tips there Newby
    Cheers Rod
  14. The Following User Says Thank You to Rocket55 For This Useful Post:
  15. #198
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    13 Post(s)
    ... and wash your starter motor down if you don't have a spill tray under the oil filters.. :-)
    John
  16. The Following User Says Thank You to jff45 For This Useful Post:
  17. #199
    Morayfield, QLD
    13 Post(s)
    Small hijack, if I may.. While there are so many GU 4.2 owners in the same thread, please give me your opinion on the vibration level you feel in the driver's seat while idling.
    I was probably spoilt by a very smooth TB45 petrol engine that idled beautifully but I'm finding the vibration from my converted TD42 auto quite noticeable. Maybe it's an auto trans thing..
    John
  18. The Following User Says Thank You to jff45 For This Useful Post:
  19. #200
    22 Post(s)
    Td's do vibrate, the have an odd firing order, if you have aftermarket engine mounts like the superior engineering ones that use a trailing arm bush. The vibrations will be amplified a bit.
    96 GQ coil/Cab
    08 G6eT
  20. The Following User Says Thank You to Ben-e-boy For This Useful Post:
