Page 542 of 1057 FirstFirst ... 540541542543544 ... LastLast
Results 5,411 to 5,420 of 10564
  1. #5411
    Nipped up the wheel bearings and while I was there converted the auto hubs.
    Replaced the thermostat with a genuine Nissan one.
    The old one didn't want to close.
  2. #5412
    Advanced morton2478's Avatar
    Mar 2015
  3. The Following 3 Users Say Thank You to morton2478 For This Useful Post:
    mudski (19th August 2015), Rocket55 (19th August 2015), threedogs (19th August 2015)
  4. #5413
    Mar 2015
    Finally fitted new intercooler
  5. #5414
    476 Post(s)
    Is that one of those ASE coolers?
  6. #5415
    Quote Originally Posted by morton2478 View Post
    What improvments have you noticed,???
  7. #5416
    Nov 2010
    Getting a life...
    38 Post(s)
    Nuffing! But wasted two days of my life which ill never get back under a Crumpdore... Sent from my SM-P600 using Tapatalk
    Same here, but it's all about V8 muscle cars in our house this week. Off to the happy thread.
    KATROL- The 2nd
    GU TD42TGi
    Silent member 1208
  8. #5417
    Nice 63 Holden ute with canopy for sale on the way to my Docs,stock std but a V6 commodore and auto
    would make it a great daily driver IMO
  9. #5418
    476 Post(s)
    Started to strip downthe TB48 calipers i scored. The pistons are a bit stuck in so a good over night soaking should free them up. Not only are they bigger than the current ZD/ TB / TD calipers by 10 mm on the disc diameter, the pistons are larger too. I am keen to see what the Troll will stop like after fitting them. I need to get the larger bore i.d master cylinder first too.
  10. #5419
    New set of platinum plugs and tappet adjustment.
  11. #5420
    Patrol Guru Chubba's Avatar
    Oct 2013
    Adelaide
    5 Post(s)
    got it dirty
    98' Ti, 4.5L, 2" lift, factory rear diff lock with front E-locker, 63% reduction gears
    "GO YOU CROWS"
