Page 7 of 8 FirstFirst ... 5678 LastLast
Results 61 to 70 of 71
Thread: Tb42 duel fuel carby issues
  1. #61
    Patrol Freak Bigcol's Avatar
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    I've had 4 cars that were Gas powered
    MK with 2.8L petrol gas
    AUII dedicated Gas
    GQ 4.2L carby petrol gas
    GU 4.2L Diesel Gas
    I do like it , but not the cost to get it fitted
    lucky, all my cars were already fitted before I brought them
    when I brought the MK - Gas was $0.21 per Liter
    used to cost $22.00 to fill the 80L tank, and used to do about 400Kms in it per week
  2. #62
    Legendary dom14's Avatar
    38 Post(s)
    Quote Originally Posted by Bigcol View Post
    oooohhhh
    nice and red................
    now, you see this here Valve -
    Attachment 60343
    this controls the amount of Gas going into your Carby
    for some strange reason, that I could never work out, whenever the bonnet is open, people like to play with it
    twist it in, or out
    and then the car runs crappy
    when you get it tuned, good idea to put a nice little mark on it and the pipe
    so if anyone DOES play with it, at least you can get it back again
    Yeah, I bought one of those power valves to fit in. Then realized it's too small for the LPG hose I have.
    It's still sitting in the car. I can't use that power valve without any mods to it, and can't find a power valve to suit the
    the Impco 300A mixer hose diameter.
    Can you guys point me to the right direction where to find a one?
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
  3. #63
    38 Post(s)
    with that "flash lube" bottle near the fire wall
    sewing machine oil is just as good, and cheaper
    Hey BigCol,
    How do you get "flash lube" or sewing machine oil to mix with LPG?
    Cheetah Outreach
  4. #64
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    Hey BigCol,
    its setup to "dribble" into the intake
    mine was on a fitting drilled and tapped into the manifold
    I think it was
    1 drop per 55 seconds
    or something like that, cannot remember off hand
  5. #65
    38 Post(s)
    I think it was
    Yeah, but what is the mechanism you use for that timing?
    Where do you get it from?
    Thanx
    Cheetah Outreach
  6. #66
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    works on the Vacuum from the inlet manifold
    http://www.flashlube.com/en/company/...ube-works.html
  7. #67
    84 Post(s)
    As well as an upper cylinder
    lubricant, I thought the
    flash lube also had a lead
    replacement that was first
    designed to coat the
    the valves in pre-unleaded
    engines. I suppose it
    isn't as crucial in an
    unleaded engine though
    as the valves are already
    hardened.
  8. The Following 2 Users Say Thank You to mudnut For This Useful Post:
    dom14 (8th August 2015), threedogs (9th August 2015)
  9. #68
    Aug 2015
    So what oil should i choose lol
  10. #69
    38 Post(s)
    Quote Originally Posted by bohall View Post
    snake oil?!!
    Cheetah Outreach
  11. #70
    Patrol Guru
    Apr 2011
    Melton
    Hi Dom,
    I suspect the IMPCO 300a has a power valve built in see item 3
    http://www.teecoproducts.com/Catalog...A%20Series.pdf
    If you are using a ring mixer - then you need a power valve
  12. The Following User Says Thank You to GQ TANK For This Useful Post:
    dom14 (21st August 2015)
