Page 6 of 8 FirstFirst ... 45678 LastLast
Results 51 to 60 of 71
Thread: Tb42 duel fuel carby issues
  1. #51
    Patrol Freak Bigcol's Avatar
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    bohall, have you gotten an update for us..........????
    really want to know
  2. #52
    Legendary dom14's Avatar
    38 Post(s)
    He's probably still recovering from last weekend's beer treatment.
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
  3. #53
    Aug 2015
    Since this post and a full tank of gas it has behaved . How do i post images on here ill put up a photo of my rig and engine bay
  4. #54
  5. #55
  6. #56
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    oooohhhh
    nice and red................
    now, you see this here Valve -
    this controls the amount of Gas going into your Carby
    for some strange reason, that I could never work out, whenever the bonnet is open, people like to play with it
    twist it in, or out
    and then the car runs crappy
    when you get it tuned, good idea to put a nice little mark on it and the pipe
    so if anyone DOES play with it, at least you can get it back again
  7. The Following User Says Thank You to Bigcol For This Useful Post:
    dom14 (7th August 2015)
  8. #57
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    now, you see all the connectors, if they look like this -
    go get your crimping machine, and whole heap of plugs, and replace every one of them
    see the end of the copper - and its brownish - dirty - need to clean them - snip the end off, scrape the ends of the wire until its clean, and replace with new plug
  9. #58
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    with that "flash lube" bottle near the fire wall
    sewing machine oil is just as good, and cheaper
  10. #59
    Aug 2015
    The guy i bought her off reckons he didnt use any oil in that container ??? Lol i like the price of gas but im new to all the gear that goes with it
  11. #60
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    Quote Originally Posted by bohall View Post
    the oil is to help lubricate the upper cylinder, as Gas is dry - so things like Valve stem seals dry out and crack and then oil drops into the cylinders, and you burn it
    and then you think your rings are shot
    also helps lube the parts of the carby that would normally have liquid petrol running over them - the butterfly's etc
