Page 110 of 187 FirstFirst ... 108109110111112 ... LastLast
Results 1,091 to 1,100 of 1862
Thread: MudRunnerTD's GQ From the Ground Up
  1. #1091
    What a massive spare.
    yes mate. Is Big Is Good!
  2. #1092
    Western suburbs of Melbourne
    12 Post(s)
    I can't believe it sits as high as your windows. Lol
  3. #1093
    Also removed my rear drawer setup which I am going to sell.
    Good to go! Happy dayz!
    I will make a full depth full width shelf at window height or a little above the tyre so I can load it up. Pretty happy with it until I want to go away for a trip then Fark knows where everything will go????? Need to learn a new system, those drawers have served me well, going to miss that.
    Hey Darren you should make a spare tyre slide. Lol. so if you need to get the tyre out you simply slide the drawer out.
    MEGOMONSTER (15th June 2015)
  5. #1094
    12 Post(s)
    Good idea Mark.
  6. #1095
    Good idea Mark.
    Yeah thats a massive and heavy tyre. You'd wanna make removal as easy as possible without putting too much strain on your back. I'd most certainly blow a pooper valve dragging that thing out of the car.
  7. #1096
    12 Post(s)
    How would you hold it, your arms aren't long enough. PML
  8. The Following User Says Thank You to MEGOMONSTER For This Useful Post:
    mudski (15th June 2015)
  9. #1097
    Time for a new rear bar with spare wheel carrier maybe?
  10. #1098
    The tread blocks actually makes it pretty easy to handle. Bloody heavy by fairly easy to manage. I fitted the tie downs out far enough that I can drag the wheel out and not jag on the tie downs.
    I will install a shelf across just above the tyre so I can pack on top. I will remove the compressor from the box on the wheel arch and mount it on the floor in front of the tyre too..
    Most of the guys I roll with have their spare inside the car like that. I will manage. Need the shelf to handle the 45lt Fridge would be ace and somewhere to mount the travel buddy with acres through the side window again is the plan.
  11. #1099
    Patrol Freak liftlid's Avatar
    Nov 2010
    6 Post(s)
    Yeah thats a massive and heavy tyre. You'd wanna make removal as easy as possible without putting too much strain on your back. I'd most certainly blow a pooper valve dragging that thing out of the car. Sent from my SM-P600 using Tapatalk
    The hard thing will be lifting the flat tyre back in when its full of mud!
  12. The Following User Says Thank You to liftlid For This Useful Post:
    Bloodyaussie (16th June 2015)
  13. #1100
    Thomastown, Melbourne
    6 Post(s)
    Quote Originally Posted by liftlid View Post
    Was what I was thinking.....
    Thought about the slide out for the spare myself and think for the effort it would be a great idea.
