Results 11 to 20 of 26
Thread: ABS/VDC warning lights when hard braking
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    Quote Originally Posted by nisshead View Post
    yep just been under there again and all sensors look good as new, i did find a chunk of wood wedged between brake lines and chasis but not damaged just cracked a couple of plastic mounts.
    I'd like to know why my brake fluid was low
    also do these have a g sensor or a yaw sensor??
    have a look under the passanger front seat is there an other sensor there for deceleration those wires might be loose or dirty its under the carpet
  2. #12
    Quote Originally Posted by roofy View Post
    Give it a couple of wacks... if the airbags go off it wasn't for the Stability Control
  3. #13
    Nope too lasy to bleed and no help ATM...LOL
    come on now is the perfect time to teach one of the boys!!!
  4. The Following User Says Thank You to rusty_nail For This Useful Post:
    Maxhead (11th February 2015)
  5. #14
    SUCH IS LIFE Maxhead's Avatar
    ACT
    Well it's been at Nissan for over a week now and still no luck. Expecting to hear something today...
    ________________________
    ______ 2017 D-Max _______
  6. #15
    bout time you did something to get your truck back on the road mate!
  7. #16
    ACT
    Nissan new slogan "We employ morons!"
    Ok, they reckon this issue is due to my steering wheel not sitting straight. Apparently the 2012 onwards vehicles with VDS have a steering wheel angle sensor which if not aligned 100% will cause issues with VDS....hmmmm
    They told me to get a wheel alignment which I did a day before taking it into Nissan.
    Looks like a adjustable drag link is in order, which funnily enough the Nissan bloke had no idea what I was talking about
  8. #17
    Well, he is correct, it will potentially cause problems.
    The steering sensor thinks you want to turn but the vehicle yaw sensor isn't.
    Not saying he isn't a moron tho
  9. #18
    ACT
    I agree the issue is most probably the wheel being off center, new drag link will sort me out..lol
    Wish I recorded the coversation though, I had to check the date and make sure he wasn't taking April's fools day piss out of me ...funny convo
    to his defence he was no mechanic and was just reading the report card
  10. #19
    How does it go again...
    'Met 3 Morons, a Cretin and 2 Retards within 20 minutes today.
    How?
    Went to the service counter and asked to speak to a manager.'
  11. #20
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    OK, Another problem which started a while back.
    When I depress the foot brake hard to the floor (stationary or moving) the ABS and VDC and SLIP lights come ON.
    Have no idea where to start.
    I have checked all brake lines, electrical wiring to the brake lights and only found that the brake fluid level is a little low(about a quater way between low and high mark)
    Everything else seems OK visually
    I have reset the ECU by disconecting the battery as well
    Stumped!
    How far off centre is your steering wheel? What lift do you have?
    I don't see how the steering wheel not sitting straight can be the cause, if it happens when stationary.
    Mine will occasionally bring on the lights when I'm traveling on dirt roads at speed. Once I cycle the ignition, lights turn off.
