Hi all,
I've got a 1990 RB30 GQ that's in great nick, but having a problem idling cold. Here's what's happening:
Cold start - starts perfect first time, but once its going need to pull hand throttle out a fair way so she idles. Idles rough at 1,000rpm, nicely at 1,300rpm.
... after a few minutes at 1,300, the revs start to drop (as the choke opens up I assume), so a bit more hand throttle is required for about 10 seconds to keep engine from stalling.
... after this, the hand throttle can progressively go in as you drive along, and the car idles nicer and nicer until the engine is warmed up and the hand throttle is back to normal (in).
So basically she idles absolutely perfectly (850rpm) when HOT (so 10 mins of running), but needs hand throttle when cold.
Any ideas what the problem could be? When the car is a about 5 minutes warm, sitting on the brakes too long (down a hill) makes the engine stall, as does switching the A/C on. When its hot it's fine no probs at all with either of these.
Have recently sprayed all the linkages and springs etc. around the carby with WD40.
The choke valve is fully closed when cold, and open full when hot (as it should be... ?)
Cheers for any help you can give,
Chris![]()
