Page 8 of 8 FirstFirst ... 678
Results 71 to 79 of 79
Thread: The will it work thread?
  1. #71
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    If you drop a dolup of solder on aluminen weld will it stick ??
  2. #72
    Patrol Freak garett's Avatar
    Jan 2015
    north
    21 Post(s)
    silver solder yep, that cheap stuff you use to join wires ... maybe maybe not
  3. The Following 2 Users Say Thank You to garett For This Useful Post:
    mudnut (19th March 2015), Sir Roofy (19th March 2015)
  4. #73
    84 Post(s)
    Why, roofy, what are you up to?
  5. #74
    Jan 2015
    north
    21 Post(s)
    probably trying to seal up a a/c line
  6. #75
    TRAFALGAR VIC
    35 Post(s)
    why, roofy, what are you up to?
    think theres a pin hole in the i/cooler
  7. #76
    Patrol Freak Gecko17's Avatar
    Mar 2013
    Quote Originally Posted by doka404 View Post
    Couple I know of but big dollars...
    Atomic Axles (don't know if it took off though)
    the other is (sorry to mention them again lol) but the Currie RockJock III Hi Pinion, they rotate the diff housing to gain more clearance..not a lot..but gives a bit extra
    Exactly what I had in mind.... Anyone know how much the Atomic's are? On a work computer that wont let me access the site.
    2006 Ser IV GU, 6.5l TD V8 Chev with 4spd Auto, 3in Lift, 35in Kumho's, 12000lb winch, Nissan snorkel, Diff breathers, lightbar + Lightforce HD spots on roofrack. Built to go bush.
  8. #77
    22 Post(s)
    Quote Originally Posted by gecko17 View Post
    exactly what i had in mind.... Anyone know how much the atomic's are? On a work computer that wont let me access the site.
    $15,000 us
    96 GQ coil/Cab
    08 G6eT
  9. The Following User Says Thank You to Ben-e-boy For This Useful Post:
    Gecko17 (21st March 2015)
  10. #78
    84 Post(s)
    They were talking of offset axles on the site I gave links to. I reckon if you combined that with rotated diff housings you would gain lots of clearance.
  11. #79
    Mar 2013
    I wonder if they would cause as many headaches trying to convert, in WA, as portal axles have? Doesn't matter that they have been engineered and certified....
