Page 460 of 1057 FirstFirst ... 458459460461462 ... LastLast
Results 4,591 to 4,600 of 10564
  1. #4591
    Patrol Guru sooty_10's Avatar
    Bendigo
    7 Post(s)
    Finished rebuilding my winch after I pulled it down to work out why it was intermittent. Turns out last time I rebuilt it I used red urethane paint on the brush housing which ended up seizing the brushes, so after working for a little while the brushes shortened enough to no longer make sufficient contact with the armature. Long story short it's all back together and functioning 100% on the bench. Now to finish putting it back in the bull bar. I also am going to run an air horn compressor through it this time so should also stop water entry and run cooler
  2. The Following 2 Users Say Thank You to sooty_10 For This Useful Post:
    lucus30 (28th January 2015), threedogs (1st February 2015)
  3. #4592
    Advanced dave97's Avatar
    Jan 2015
    Lubricated the hinges on the doors and went ebaying for electrical cable
  4. #4593
    176 Post(s)
    Re-located the winch control box. I hated the way it looks sitting on the bullbar. So toying with this idea, of mounting it behind the grill onto that center bracket that the grill rests onto. Bolted on, fitted and worked out absolutely perfectly, it's as if it was designed for it.
    Now these Zeon boxes are meant to be fully sealed, so don't trust it, because not it's somewhat sitting on it's side, I'm unsure about rain from above. Otherwise it's going elsewhere.
  5. The Following User Says Thank You to Hodge For This Useful Post:
  6. #4594
    Expert Patrol'n's Avatar
    Oct 2014
    WA
    Last couple of weeks, I have added a rhino rack awning, rhino roof tray, racks etc, a safari snorkel, and 50mm tough dog suspension lift, amazing the difference the new suspension makes!
    93 GQ wagon, RB30, extractors, 2 inch tough dog lift, 5 spd, A/T KO2 32's, steel winch bar, rated recovery points, red arc dual battery set up, rhino roof racks, UHF etc etc. Slow and steady might not win the race but it gets me there eventually...
  7. #4595
    Quote Originally Posted by Patrol'n View Post
    Pics or it didn't happen.
    Oct 2014
    WA
    I would love to add pics, I've tried before off my iPad and it won't upload them??? My computer won't connect to the internet anymore, something wrong with it but it's old and I can't be arsed fixing it. Can someone tell me if there's a trick to uploading pics off an iPad?
  9. #4597
    Patrol God Stropp's Avatar
    36 Post(s)
    Yes get the forum runner app and upload the pics through that, easy as
  10. #4598
    Feb 2011
    Shed
    45 Post(s)
    Pulled the centre of the dash out to get to the air vent that sh1t itself on the way to Nisspissds meetup. All good except now cant get demist only. Still better than demist only though
  11. #4599
    yes........ get an android tablet of phone instead and ditch the crapple piece of poop where no one has the misfortune of ever coming across such a horrid device again!!!!! hahahahahaha
    either that or MudrunnerTD or Oncedisturbed, or another member might be able to give you some pointers
  12. The Following 3 Users Say Thank You to Clunk For This Useful Post:
    Hodge (1st February 2015), Majestic (10th February 2015), mudski (1st February 2015)
  13. #4600
    176 Post(s)
    A man who knows his stuff. There is still hope left in humanity... I'd buy you a beer just for this!
  14. The Following User Says Thank You to Hodge For This Useful Post:
    Clunk (2nd February 2015)
