Results 1 to 10 of 14
Thread: Cost of fitted snorkel to GU patrol?
    Dec 2014
    Hi guys, just purchased my first ever Nissan Patrol! It's a 2001 GU. It's pretty stock but is in fairly good knick.
    Question, I've purchased it from a dealer and they're offering to install a snorkel for me. Just want a get a ball park idea of what a fitted snorkel to a GU patrol should cost?
    Also, are there any particular brands, fitters that I should take it to, or is a fairly straight forward mod and would any half decent operator be able to install it?
    Many thanks.
    You could do it yourself if your handy with tools , but it should take a bit over 3 hrs I think
    most 4x4 shops would know how its done
    Where abouts in Melb are you I could sort something out for you
  3. The Following User Says Thank You to threedogs For This Useful Post:
    Bucko391 (18th January 2015)
    brisbane
    If I had my time again I'd get a safari or similar that can take a pre filter and that the head can do a 180 degree turn not like the genuine one the factory snorkel just turns to the side. . Though I've never had any issues with my factory one. A snorkel will set you back 75$ through to 600$ + fitting. It is easy enough to fit one with the right tools.
  5. The Following 2 Users Say Thank You to megatexture For This Useful Post:
    Bucko391 (18th January 2015), ova50 (19th January 2015)
    I went TJM which I think is air teck or Safari.
    Steer clear of those cheap ones the templates aren't to scale and sometimes they dont fit the body contours.
    If you like your pride and joy go a brand name snorkel
  8. #5
    Patrol Freak Bacho86's Avatar
    Mar 2011
    14 Post(s)
    I had a safari snorkel installed in my 2008 GU for around $600-$700 from memory - I had a look around at the real cheap eBay ones, a tjm / airtec and also factory nissan (which I think are an airtec too), but personal preference I think the safari looked better.
    I've heard good thinks about about the ironman snorkels as well, and they can be had for a little bit cheaper.
    I was going to install it myself, but didn't have all the correct size / good quality holesaws so was easier to pay to have it done
  9. The Following User Says Thank You to Bacho86 For This Useful Post:
  10. #6
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    I had an Ironman fitted and it is good. When I was looking around the safari seemed the best but a bit expensive for me. Ironman is good quality I think. I Had mine fitted as I was a bit apprehensive about cutting big holes in the guard. As TD said watch out for really cheap ones as I am told the plastic may warp and/or disintegrate in the sun. Not a good look in Australia.
    No one wants a wilted snorkel.
  11. The Following User Says Thank You to 4bye4 For This Useful Post:
  12. #7
    brisbane
    A mate bought one off ebay for 75$ and we fitted it about 3 yrs ago and its not changed, it had a 6mm gap between it and the body when it was installed but the gaps not changed.
    I think it was bloody good for 75$
  13. #8
    Dec 2014
    Thanks all for your responses. Will definitely go the brand name (TJM/Safari). The dealer couldn't tell me what sort of snorkel they were fitting so I think I'll just leave it for now. Will look into doing it myself as I am ok with the tools
  14. #9
    brisbane
    Its easy to fit we fitted the 75$ snorkel with a 5mm drill bit and a steak knife cos the cheap bastard was too tight to buy a hole saw lmao
  15. The Following User Says Thank You to megatexture For This Useful Post:
    neet_wagon (21st January 2015)
  16. #10
    Patrol Guru sooty_10's Avatar
    Bendigo
    7 Post(s)
    Quote Originally Posted by Bucko391 View Post
    Dealer will most likely install a genuine Nissan one, which are made by TJM and very similar if not the same as a TJM Airtec
  17. The Following User Says Thank You to sooty_10 For This Useful Post:
    Bucko391 (25th January 2015)
