Page 5 of 7 FirstFirst ... 34567 LastLast
Results 41 to 50 of 67
Thread: show us your remote winch solenoid location
  1. #41
    334 Post(s)
    Yea good thinking. What's that stuff like to get off though.
    Terrible! assume once on its on. I used it and expected to just clean up the edges with a razer blade! Yeah good luck with that!
  2. #42
    Ok. So back to lug / terminal covers lol
    334 Post(s)
    It comes with a crappy lid mounted brush which is less than average, just do a neat job and don't alow for cleanup as I had and it's great stuff mate. I just did it thinking I could clean up the edges but couldn't.
    Good stuff for what it is
    Jump on Gigglepin web site and they sell the lug boots for $5 each I think or less
  4. #44
    Apr 2011
    Melton
    I have my solenoid setting next to the battery as per one of the earlier posts. My next project is to pull it out of its box and remote mount the controller. _its a pain openong the bonnet to plug the contrller in.
  5. #45
    How many of you run isolators inline to the winch?
    334 Post(s)
    I run an isolator to the switching side of the Solenoid mate, easy to keep it dead that way as its low current.
    With my new setup though I am fitting a 600amp constant rate kill switch on the back of the centre console to isolate the power to the whole 24v system should everything go to poo.
  7. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    BigRAWesty (9th December 2014)
  8. #47
    Expert mjr350's Avatar
    Sep 2014
    Port Macquarie
    I have mine sitting up in the corner next to the booster. Its tight but there's a few bolt holes than allow for a bracket to be made up. A nutsert kit is your best friend in these situations. I didn't own one at the time when I installed the winch but I sure as hell do now. Also ran the plug down to behind the bonnet release lever in that little recess.
  9. #48
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    13 Post(s)
    You can even wire in a parallel rocker switch as an option/backup to the hand controller.
    John
  10. The Following 2 Users Say Thank You to jff45 For This Useful Post:
    Agronaught (10th December 2014), BigRAWesty (10th December 2014)
  11. #49
    Yea this is my plan as well and an isolator switch. But as always time and funds are the key
    Morayfield, QLD
    13 Post(s)
    The 2 small rocker switches isolate the controls. I have a nice bright LED that tells me if I left them on..
    John
