Page 4 of 7 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 67
Thread: show us your remote winch solenoid location
  1. #31
    brisbane
    Quote Originally Posted by 04OFF View Post
    Don't worry Troy, you've actually got to "go" 4wdriving to get stuck and need a winch (bwahahahah !)
    It's getting that way!
  2. #32
    Patrol Guru cgm's Avatar
    Jul 2012
    Ballarat
    Touch Wood. They are a Dog of a thing for Sh1tting themselves just when you need them most.
    Yeah I've done three relays over about 5 years, yet one of my mates has never done one in probably 17 years he's had the winch. Mucking around with a hammer or screwdriver to "convince" it is not good when you really need it. It's something I should swap out on my current truck. Hmmm, another suggestion for Christmas maybe?
    Is there any particular brand that we should be looking for in the solid state replacement?
    Thanks, Cameron
    No Patrol now - Just good memories!
  3. #33
    334 Post(s)
    Quote Originally Posted by cgm View Post
    Allbright is the best on the market IMO. Itis the Gigglepin brand and is what I have just changed too. A little more expensive but will work when you need it too.
    I have also just swapped to 70mm/sq for everything.
    I am mounting my solenoid on the end of the motor and you can buy longer motor bolts to allow for it to be mounted there.
  4. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    cgm (9th December 2014)
  5. #34
    334 Post(s)
    Kallen, open up the control box and I bet you will find a Solid State Slenoid inside, the ox is just packaging, feel free to strip it out if it will make mounting easier.
    BigRAWesty (8th December 2014)
  7. #35
    I upped mine to 70mm2. You even work in an electrical suppliers you get it cheaper than I do., if you are going to up grade it.. upgrade the shite out of it
    If I was doing a high mount I would go bigger for sure, 35mm^2 is plenty for my application
  8. #36
    After seeing the few above I think I will strip it down. No need for wasted space when it's at a premium
    MR.. Here is the guts. Not the smallest unit around. But will be a much easier install
  10. The Following 2 Users Say Thank You to BigRAWesty For This Useful Post:
    Bacho86 (9th December 2014), MudRunnerTD (9th December 2014)
  11. #38
    Quote Originally Posted by Pokey View Post
    Mine was mounted to the winch until recently I went to use it and found it was full of gunk and stuffed so relocated the new one to the engine bay. <img src="http://www.nissanpatrol.com.au/forums/attachment.php?attachmentid=52487"/>
    Well mate thanks for the inspiration.
    I found the perfect location.
    Currently gluing the wireless setup under the same cover and I'll run it in a protective tube out beside the top bolt.
    So now I have to finish bar, get cables made and wire it up.
    I'm in to minds though if I'll need terminal covers. I think I will be unsure if I'll find them locally.
  12. The Following 2 Users Say Thank You to BigRAWesty For This Useful Post:
    Bacho86 (9th December 2014), Pokey (9th December 2014)
  13. #39
    brisbane
    Brush it up with some liquid tape just do a few coats even if its just on the pos
  14. #40
    Quote Originally Posted by megatexture View Post
    Yea good thinking. What's that stuff like to get off though.
