Results 1 to 6 of 6
Thread: Bushes
    Aug 2014
    Perth
    10 Post(s)
    Bushes
    Hey all,
    The old girl GQ needs new suspension bushes and I was wondering if this has them all or if i need to get more not contained in the kit http://www.ebay.com.au/itm/Full-Susp...3D330839511333
    Also whats the best way to do this?
    Expert Crate's Avatar
    Apr 2014
    Bonbeach
    Yes mate that has everything you need, I would suggest that you consider spending the extra money for genuine bushes instead of those aftermarket ones though. Genuine are higher quality and will last longer and perform better.
    GQ highmount, lockers, barwork, 3-Link front, long arms, V8, cage, duct tape, cable ties and 35's
    Oct 2014
    Swan Valley
    I second that. Whiteline bushes are good for your panhards. If your car has a lift, make sure you get castor correction bushes for the radius arms
    84 Post(s)
    Quote Originally Posted by Sharky1 View Post
    I have been advised that the castor correction bushes wear out quickly. Superior engineering make radius arms for different lift heights.
  5. #5
    Apr 2014
    Bonbeach
    Not a fan of drop radius arms personally, the only thing that really corrects a radius arm geometry (and castor angle) after a suspension lift is drop boxes. The reasoning behind this is that it brings the rear of the radius arm down to match the amount you have lowered the front diff.
  6. The Following User Says Thank You to Crate For This Useful Post:
    mudnut (30th October 2014)
    Apprentices Rule!!! Punderhead's Avatar
    Nov 2011
    Toowoomba, QLD
    Quote Originally Posted by Crate View Post
    They also lower your gearbox a little for a better angle on the driveshaft I do believe. I'm going to fit mine soon so I'll let you know
    GO HARD OR GO HOME!!!
    My rig HERE http://www.nissanpatrol.com.au/forum...Moneypit-89-GQ
    WARNING: Towballs used in a recovery can and DO KILL people!!!
  8. The Following User Says Thank You to Punderhead For This Useful Post:
    Crate (30th October 2014)
