Page 411 of 1057 FirstFirst ... 409410411412413 ... LastLast
Results 4,101 to 4,110 of 10566
  1. #4101
    Nov 2010
    Getting a life...
    38 Post(s)
    Where did you move it to, pics?
    I keep doing the same thing.
    Made a bracket so it sits in front of bar instead of under it. Did the same with the gas filler by mounting it in the rear bar. Will take pics tomorrow.
  2. The Following User Says Thank You to katwoman For This Useful Post:
    TPC (18th September 2014)
  3. #4102
    477 Post(s)
    Replaced and moved tow plug after smashing it off for the 7 millionth time last w/end.
    I bought some of the flat seven core wire and ran a trailer lead from the right tail light and it simply stores in where the jack is. No more mud filled plugs.
  4. #4103
    Patrol Freak lhurley's Avatar
    Oct 2011
    Brisbane. Manly West.
    Mine is the same, just on the other side. Easier to slip it out the little door.
  5. #4104
    Patrol Guru sooty_10's Avatar
    Bendigo
    7 Post(s)
    That's exactly how I was going to wire mine up. It's how my commodore is and you only pull it out when you need it.
  6. #4105
    Patrol God Stropp's Avatar
    38 Post(s)
    I did nothing to the patrol but I did get the Harley out of mothballs for summer
  7. #4106
    Western suburbs of Melbourne
    12 Post(s)
    Had the battery on charge last night.
  8. #4107
    Expert Ian2011's Avatar
    Sep 2011
    Australia
    New bfg AT 33s. So much more pleasant to drive not listening to the howl of the previous muddies. Now I can hear the v8 growel much better.
    6.5 Chevy, roof rack, uhf, Spotties, dual batteries, ARB Bullbar, 12, 000lb winch, (unfortunately not Warn) Safari snorkel, Dieselgas conversion, 2in lift, engine watchdog fitted, boost/EGT guages, front elokka fitted, rear power supply mods, turbo timer, dual wheel carrier rear bar.
  9. The Following 2 Users Say Thank You to Ian2011 For This Useful Post:
    Hodge (19th September 2014), Stropp (19th September 2014)
  10. #4108
    Nov 2010
    Getting a life...
    38 Post(s)
    That's a great idea. But I can't open my spare wheel carrier with camper on.
    KATROL- The 2nd
    GU TD42TGi
    Silent member 1208
  11. #4109
    So I've started pulling down again..
    This time to fit keyless entry security, long range tanks and fix electronics.
    And hopefully some freaking side steps
    But also found my elec windows issue.. The amp unit... It's fubar'd
    Hopefully this time the bloody 80 doesn't break down and I can finish what I start
