Page 400 of 1057 FirstFirst ... 398399400401402 ... LastLast
Results 3,991 to 4,000 of 10561
  1. #3991
    .......... TPC's Avatar
    63 Post(s)
    Quote Originally Posted by Chubba View Post
    Put a set of 285/75r16 Maxtrek Mud Trac on my pride and joy for $200 a piece fitted and fitted manual hubs
    How much were the manual hubs and how easy was it changing them?
  2. #3992
    Patrol Guru Chubba's Avatar
    Oct 2013
    Adelaide
    5 Post(s)
    Quote Originally Posted by skippy201284 View Post
    very nice and why u go back to manual hubs for chubba
    One of the original auto hubs had cracked so I had to replace either way and I believe the manual hubs are stronger so a quick look around for a pair of hubs at $185 and I was sold. Not too much messing around to put them in. my brother and I did it in an afternoon slowly working out how they went together.
    98' Ti, 4.5L, 2" lift, factory rear diff lock with front E-locker, 63% reduction gears
    "GO YOU CROWS"
  3. #3993
    Western suburbs of Melbourne
    11 Post(s)
    Looks like the starter battery is failing.
    And the second battery is failing a load test.
    Second battery only changed in February.
    Might need ideas.
    If my second battery is still under warranty, and replaced, I'm thinking of making it my starter.
    Then decide what to do for second battery.
    More Ah more crank, longer lasting battery than what I currently have, which is the Century Ultra High Performance 4WD battery.
  4. #3994
    Expert Patrol-Guy's Avatar
    Dec 2013
    NSW
    Fitted my front and rear Harris Hardarse diff guards.
    Thank you Mr Harris.
  5. The Following User Says Thank You to Patrol-Guy For This Useful Post:
    Family4x4 (19th August 2014)
  6. #3995
    Patrol Freak gaddy's Avatar
    redlands
    Might need ideas.
    I had a century 4wd replaced under warranty last week , bit of a hassle as they had the battery for a day and a half to test it and even though they are 770cca they will not deam it as warranty unless it goes below 650cca as that is still deamed a good battery ! Mine was just over that but because it is deamed enough for the average passenger car , Wasn't till I told them it was starting a 6cyl diesel that they agreed to replace it , and I only got balance of existing warrenty (2 months ) on the new one .
  7. #3996
    Patrol Guru sooty_10's Avatar
    Bendigo
    7 Post(s)
    Finally wired up some rear LED strip lights in the barn doors. Also last week wired in a digital temp controller for the Engel so now I have constant accurate temperature inside my fridge with no trial and error I also have a wireless temp probe so I can see what temps are doing in the cab or while around the camp.
  8. #3997
    11 Post(s)
    I realised today, I'm travelling over 110kms to and from work a day.
  9. #3998
    Oct 2011
    Essendon
    Well, just as well you're not driving a TB then.....
    Sent from my iPhone using Forum Runner
  10. The Following User Says Thank You to Drewboyaus For This Useful Post:
    MEGOMONSTER (19th August 2014)
  11. #3999
    176 Post(s)
    Dropped it off to the mechanic. Will know the outcome next few days, once hes surveyed a few things and chucked it on the dyno. Hopefully she'll be ready by end of week with some newly found powa ??!!!!!!!
    OH wait who am i kidding, its a 3L ...
    Hardcore
    Coffs Harbour
    G'day Lounge Lizards,
    Finally removed the majority of my accessories from my GU 4.2 turbo diesel patrol wagon.
    PS, Hopefully will have removed my lockers soon, so that my Patrol will be ready for sale.
    Regards,
    PMC
    The halls been rented the bands been paid, time to see you dance!
  13. The Following User Says Thank You to PMC For This Useful Post:
    Stropp (19th August 2014)
