Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 48
Thread: Cheap Battery monitor.
    Patrol Guru Family4x4's Avatar
    Jan 2014
    Victoria
    Quote Originally Posted by megatexture View Post
    What were you trying to achieve? Car dual battery or a camper setup ?
    I'm tempted to get one just to see what its like lol . HMmmm
    Car dual battery. I have just started the install. I would be interested in something like this to be able to monitor the cars batteries.
    In any moment of decision, the best thing you can do is the right thing, the next best thing is the wrong thing, and the worst thing you can do is nothing.
    Theodore Roosevelt
  2. #12
    Jul 2014
    3 Hrs West of Brisbane
    Not really. The way that these monitors are able to be used as a 'Battery fuel gauge' is by first the capacity of the battery being set by the owner. Eg. 100Ah. When the battery is full (determined by voltage) any usage draws Ah's from it. The monitor can then tell how much of the capacity, as a percentage, has been used. Likewise it can add Ah's when being charged. They are smart enough to recognise charging & usage at the same time. It is not uncommon for my monitor to show +ve amps from the solar whilst the fridge is running for example, because there is more coming in than is going out. The problem with switching between two different batteries is that each battery capacity would likely be different, meaning the monitor would need to be reset. Even if they were exactly the same it would still take a little while for the monitor to suss out the other battery's SoC. So not really practical. Besides I can see no point monitoring a start battery in this way. As long as it has sufficient voltage to start the vehicle that is all that is needed, & most dual battery systems have a means of protecting against draining the start battery. For setups with more than one aux batteries, this meter could monitor both if they were connected to each other (would see them as one large battery). If it is desired to not connect them together then a separate monitor for each battery would do the job.
    My question about these is does the charge current from the alternator need to go through this meter (shunt?) to maintain the charged % etc as well as the items drawing power? If so not the best for dual batteries, ideal for portable power pack though.
  3. #13
    476 Post(s)
    Quote Originally Posted by Bloodyaussie View Post
    Worth a punt at that price...
    Yes it is... I have ordered one to put in my camper. We'll see what its like when it arrives...
  4. #14
    Ballarat, Vic
    176 Post(s)
    Quote Originally Posted by MuddyTroll View Post
    Yes. Shunt is on the negative.
  5. #15
    Ballarat, Vic
    176 Post(s)
    Will look forward to getting your feedback.
  6. #16
    Patrol Guru sooty_10's Avatar
    Bendigo
    7 Post(s)
    http://www.ebay.com.au/itm/DC-120V25...item27d29d0d45
    This one looks the same as the OP posted, but it is cheaper with free postage. However it doesn't have an external shunt included, it does state that it has an internal shunt? Thoughts Cuppa.....
    they are all from China
  7. #17
    brisbane
    Only 30A, It wouldn't be suitable for heavy power uses, but I would like to see the shunt that comes with the link cuppa posted when you get it mudski
  8. #18
    Ballarat, Vic
    176 Post(s)
    Quote Originally Posted by sooty_10 View Post
    http://www.ebay.com.au/itm/DC-120V25A-Volt-Amp-Battery-Capacity-AH-Power-Combo-Meter-Charge-Discharge-Timer-/171037232453?pt=AU_B_I_Electrical_Test_Equipment&h ash=item27d29d0d45
    I would concur with Megatexture's reply. 30A doesn't leave a lot of leeway once a few things are switched on ..... but of course it depends what accessories you have (or may add in the future).
    MT, there is a pic of the shunt in the ad linked to in the OP.
    Same seller also has similar rated to 200A if required, but 100A would suit most camping set ups.
  9. #19
    Bendigo
    7 Post(s)
    Yeah fair enough on the 30A internal shunt. I just realised that the ones I'm looking at are actually the same seller you posted up Cuppa He has them in 50A, 100A, 200A, 300A and 500A. All for about an extra dollar dearer than the last one. Is there any downside to going a larger, say 200A or 300A shunt?
  10. #20
    Ballarat, Vic
    176 Post(s)
    Not that I am aware of. If you were planning to run a winch off the battery(s) being monitored going for the 500amp one would save having to bypass/reset the monitor as I have to do with my 100A monitor.
  11. The Following User Says Thank You to Cuppa For This Useful Post:
    sooty_10 (23rd July 2014)
