Results 1 to 10 of 10
Thread: pertronix and condensor/ resistor
    Advanced scubasteve's Avatar
    Redland Bay, QLD, AUS
    gday guys
    After looking into the Maverick a little more ive discovered that it already has a Pertronix lobe sensor module installed with a bosch GT40R coil. I just wanted to double check how it should be set up in regards to a resistor coil and condensor as ive read a couple of times these things are normaly removed once the pertronix has been fitted. This is the set up I currently have:
    cheers in advance
    Apr 2011
    Melton
    You need to remove the condensor.
    With a GT40R you need to have a ballast resistor.
    If you upgrade to a gt40 or a pertonix coil - then you remove the ballast (just connect all the wires together at 1 end.
    You get a bigger spark running the coil at 12 volts (no ballast resistor)
    Note = the round gold colour device mounted to the coil in the above photo is a RF suppressor. The condenser is mounted on the side of the carby
  3. The Following 2 Users Say Thank You to GQ TANK For This Useful Post:
    scubasteve (20th June 2014), taslucas (17th June 2014)
    Quote Originally Posted by GQ TANK View Post
    Cheers mate I assume the condensor is already off and that I do need the rf surpressor?
    1989 Ford Maverick: TB42s Carby, Snorkel, 3" king spring suspension lift, 2" body lift, aftermarket extractors, 33x12.5 mickey t MTZ's, 2.5: Sports Exhaust
    Apr 2011
    Melton
    The rf supressor will stp rf interferance to you am / fm radio and CB
  6. The Following User Says Thank You to GQ TANK For This Useful Post:
    Jul 2014
    If the condenser is left on could it cause any problems?
    Also I put in a bosch coil for use with electronic ignition should I do anything to my ballast ?
    sorry for hijack
    Apr 2011
    Melton
    You dont need the condensor when you have a pertonix.
    You need to check the wiring of the vehicle that the bosch coil came from - some vehicles do run a ballast with electronic ignition. The ballast is designed to reduce the current flow though the coil.
  9. #7
    Jul 2014
    Hey man thanks for the info
  10. #8
    sunshine coast
    Would the gt40 coil be equal to the flamethrower coil
    I put the flamethrower 2 coil in my patrol and the coil was to hot to touch (as hot as stovetop)
  11. #9
    Apr 2011
    Melton
    What pertonix ignition are you running?
    The flamethrower 2 coil has Ultra Low 0.32 primary resistance - the lower the resistance the more current flow = coil will get hotter
    The flamethrower coil has either 1.5 or 3 ohms you might need to swap with a flame thower
    A gt40 has a resistance of around 3 ohms
  12. #10
    sunshine coast
    I have the ignitor2 and I ended up running the flamethrower2
    it was running hot so I swapped it to old coil now its back in and running properly now
