Page 379 of 1057 FirstFirst ... 377378379380381 ... LastLast
Results 3,781 to 3,790 of 10561
  1. #3781
    .......... TPC's Avatar
    63 Post(s)
    Chopped the mesh out of the bottom half of the cargo barrier so I could use the wasted space between the cargo barrier and the back of the drawers.
    Also fitted some LED lights to the small barn door.
  2. #3782
    Advanced fourj's Avatar
    Jan 2014
    Installed new UHF aerial, after some p@!:k decided it was more useful to them than it was to me last weekend!
    Even had to unscrew a grub screw to take it!
  3. #3783
    Expert clubbyr8's Avatar
    Penrith, NSW
    Ran cabling for the reversing camera and extra reversing lights...
    GROOVY GUVII
  4. #3784
    Patrol God Stropp's Avatar
    36 Post(s)
    Not me but got the patrol back after getting it serviced and checked over prior to the Simpson trip also finally got the winch fitted albeit just a crappy Chinese on until I can afford a decent one.
  5. #3785
    176 Post(s)
    Just upgraded the interior LED lights to these large babies, will see what theyre like tonight . I also realized they fit perfectly in the reading lights up front, so I ordered another set.
    Attachment 45417Attachment 45418Attachment 45419
    These were it.
    http://www.ebay.com.au/itm/320924739...84.m1497.l2649
  6. The Following 2 Users Say Thank You to Hodge For This Useful Post:
    threedogs (7th June 2014), TPC (7th June 2014)
  7. #3786
    176 Post(s)
    Just finished mounting the sidesteps/running boards donated to me by GU CAMPER who has replaced them on his truck with some proper rocksliders. Wish I'd done the driver side first, that way I would have known how they were supposed to sit, but I didn't, I did the passenger side first. This was the side where GU CAMPER had used them as rocksliders. Much cursing & a bit of gentle persuasion with an angle grinder, a set of files, a couple of hacksaw blades & a 3lb lump hammer finally saw it mounted. Drivers side went on no trouble. It was only then I realised that the passenger side was bent up a couple of inches & a bit rearwards too. I reckon he was having fun when he did that! Still they are on, & look alright, & more importantly (& the reason for fitting them) will now protect the sills from the gravel attack they have been susceptible to.
    Thanks Andy.
  8. The Following User Says Thank You to Cuppa For This Useful Post:
    Stropp (7th June 2014)
  9. #3787
    36 Post(s)
    Mounted the radio antennae and ran the cable to the inside of the cabin, just need to remember to seal the firewall up now to stop the water getting in.
  10. #3788
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Drove it then heard it go bang a few times from the driver side front hub/cv.... Hmmmm....
    Hubs in 2wd or 4wd: 5 "bangs" in 20 mins.
    Hubs out, 2wd no bang but an occasional slight squeak.....
    Any ideas?
    Hello from Under Down Under!
  11. #3789
    I drove my to work and then I drive it home, same as yesterday.
    Sorry guys I had to do it at least once.
  12. #3790
    22 Post(s)
    Any ideas?
    Hahaha..... sound like the front end has to come apart... I would say cv.
    96 GQ coil/Cab
    08 G6eT
  13. The Following User Says Thank You to Ben-e-boy For This Useful Post:
    taslucas (8th June 2014)
