Page 376 of 1057 FirstFirst ... 374375376377378 ... LastLast
Results 3,751 to 3,760 of 10566
  1. #3751
    Is possible to fry your ecu and other electrics....
    Maybe but everything still works...luckily.
    Im wondering how much better the welds would have been if I mig welded using gas. As welding the thinner sections still blew holes. But after a few grinds, then rewelds it all came up pretty good.
  2. #3752
    Installed my new 28 smd led roof lights.
    :-o I can see....
    84 Post(s)
    Get a tig set up. Easier to use, puts less heat into the work, cleaner weld, excellent strength and uses less gas.
  4. #3754
    Too late bud as I just bought the mig. I need a crap load of new tools, BA can vouch for this, lol, so mabye down the track I will.
  5. #3755
    Hoping my sender unit is going to be ok for the aux tank!
    Being testing it for half an hour now, it definitely reads resistance when moving the float but It's not steady, jumps around and sometimes goes back to the original reading from when float is at bottom although float is at top.
    All connections seem fine and is clean on the sender slider reading thinngy, not bent and actually looks in pretty good condition but it worries me.
    Not sure what to do as it does read changes in float movement....Bugger!!!!
  6. #3756
    I'm thinking about getting a new one just because... While it's out
  7. #3757
    I know....really do not want to take it back out again!!!!
  8. The Following User Says Thank You to AB For This Useful Post:
    Stropp (26th May 2014)
  9. #3758
    Patrol Guru cgm's Avatar
    Jul 2012
    Ballarat
    ... the sender slider reading thinngy ...
    Love the technical description.
    Thanks, Cameron
    No Patrol now - Just good memories!
  10. #3759
    Jul 2012
    Ballarat
    Where are the next pics Mudski? Came back tonight to see what it was, now after being told it's obvious, but love to see how it comes up ...
    Thanks, Cameron
  11. #3760
    Quote Originally Posted by cgm View Post
    I'll wait until I'm finished. Well, atleast to the painting part. I then will start a DIY thread for others to see how I did it.
