Results 11 to 20 of 23
Thread: nissan patrol y61 4" lift kit
    Hardcore jack's Avatar
    Ballarat Area
    26 Post(s)
    Quote Originally Posted by seekers282 View Post
    well mine is right hand driver vehicle..
    OK go with Megos suggestion then, I wasn't sure if they were left hand drive where you are.
    Jack
    2024 Isuzu MUX
  2. The Following User Says Thank You to jack For This Useful Post:
    seekers282 (26th April 2014)
  3. #12
    Advanced thebrod's Avatar
    Sep 2013
    excuse my ignorance, and for hijacking your thread - but what is a dropbox???
  4. #13
    Feb 2014
    brunei darussalam
    Quote Originally Posted by thebrod View Post
    you can google image it type patrol gq/gu drop box mate..
  5. #14
    Sep 2013
    lol will do - my first google came up with a whole heap of stuff about the dropbox file sharing site!
  6. #15
    Feb 2014
    brunei darussalam
    i wish i could upload the picture here..but it always say "invalid image" must be this ios app..try this link
    http://www.nissanpatrol.com.au/forum...ift-kits/page5
    Sent from my iPhone using Motorculture mobile app
  7. #16
    Feb 2014
    brunei darussalam
    No need to use both together....
    Use Drop Boxes over Caster Correction Bushes, as you can then keep the Standard Nissan rubber Bushes - much better
    Mic
    how bout for the rear?should i change the upper arm trailing to adjustable type?or i just let it be..
  8. #17
    Legendary happygu's Avatar
    Yes, I would change them over to correct the geometry
    If you don't, you will find that you will have some driveline vibration from incorrect pinion angles.
  9. The Following User Says Thank You to happygu For This Useful Post:
    seekers282 (29th April 2014)
  10. #18
    334 Post(s)
    Yes drop boxes instead of cater plates. Caster plates are junk.
    Yes if your rear diff pinion angle needs adjusting then adjustable upper arms are the go mate for sure.
  11. The Following User Says Thank You to MudRunnerTD For This Useful Post:
  12. #19
    476 Post(s)
    In a nutshell. The best thing man has created for a Patrol. Castor correction bushes are junk as other have mentioned.
    Edit : Dropbox is also awesome for your smart phone too. Best app I have. Well one of them.
  14. #20
    Feb 2014
    brunei darussalam
    well..about the vibration..i think its happening already..the gear seems to vibrate at the final gear and dissapper after that..i gonna look for the adjustable upper link..thanks mate
