Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: EGT/Boost Gauges
    Feb 2014
    Darwin
    Question EGT/Boost Gauges
    So I was wondering which way to go with boost/egt gauges, I've had a look around on various sites at different ones but still have no idea what to go for. digital or mechanical? Dash mount or pod? dual gauges or multifunction? I need reliability and accuracy without having to go and rob a bank. I'd also be very interested to know which brands to avoid.
    Thanks in advance.
    476 Post(s)
    Just avoid cheap pretty much. I use Mc.Nally, many others use VDO or Autotron.
  3. The Following 2 Users Say Thank You to mudski For This Useful Post:
    Robo (20th February 2014), rookiepatroller (19th February 2014)
    Feb 2014
    Darwin
    what about this?
    http://www.auberins.com/index.php?ma...roducts_id=357
    I was thinking about mounting it in the centre console below the tuner.
    Western suburbs of Melbourne
    11 Post(s)
    These are mine but abit expensive.
    I went with Autron.
    Expert patrol2.8's Avatar
    Nov 2011
    vic
    I use auberins for egt and and also head metal temp for boost i just use a sas gauge but will be swapping that to a digital read out as i find digital much better
    Theres only one thing tougher than my truck............. YES DEAR GOING TO DO THE LAWNS NOW
    WARNING: Towballs used for recoveries,can and do kill people and damage property
    Patrol Guru sooty_10's Avatar
    Bendigo
    7 Post(s)
    I also use auber instrument gauges. I find they are extremely accurate and easy to read. They also have max/min feature and an external output triggered by user set alarm levels for use with a relay etc. They are versatile and capable of been used with a variety of sensors so you can switch the use of them without having to buy another gauge. I have 3 mounted below my stereo red is EGT, green is boost, and blue is now hooked up to water temp. I also have another air intake temp sensor and when I get my intercooler setup I'll change water temp to air intake for a while. Tried uploading a pic but motor culture isn't letting me for some reason. I'll try again later....
  8. #7
    I use Speco and when combined with the ECU-talk very accurate.
    if you require a pillar pod give me a pm.
    what if you want a double din head unit down the track
  9. #8
    Sending pm about pillar pod 3dogs
  10. #9
    Jan 2013
    Im loving the look of the autrons!
  11. #10
    176 Post(s)
    I have an Autron gauge, and it's pretty good. Being able to set alarms on it at set points really helps when tuning up the NADS !
    Only gripe I have with the Autron is how bloody bright they are at night driving.
