Page 26 of 50 FirstFirst ... 2425262728 ... LastLast
Results 251 to 260 of 498
Thread: Outback Ideas Recovery points
  1. #251
    Who's manuel ??? lol
  2. #252
    Oct 2010
    Old Bar, NSW
    13 Post(s)
    Didn't realise you weren't, but now you are.
    Good on ya John.
    Macca
  3. The Following User Says Thank You to macca For This Useful Post:
    threedogs (30th August 2013)
  4. #253
    good on ya john for jumping onboard mate!
  5. The Following User Says Thank You to rusty_nail For This Useful Post:
  6. #254
    Isnt he the guy that works at Farty Towels with Basil?
  7. #255
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Welcome John
    Any forum member discounts??????????????????? *LMAO*
  8. #256
    brisbane
    I'd be happy with an intro!
  9. #257
    .......... TPC's Avatar
    63 Post(s)
    Onya John, good quality stuff.
  10. #258
    Oct 2011
    Essendon
    Hi TD,
    What are my options on a GQ for front recovery points? I'm running an ARB winch bar if that has an impact.
    cheers,
    Drew.
  11. #259
    I have a replacement for the drivers side OE hook,
    or if you want to use two you'll need to remove the
    bulbar and make a plate to slide inside chassis,
    Mudski fitted two using this method.
    The plate also has provision for one of those 4.7t black hooks with the spring steel keeper
    Edit reason is you only have captive nuts on the drivers side
  12. #260
    Oct 2011
    Essendon
    What about something to bolt up using the same bolts that are used on the bar?
    They make use of a plate with captive nuts attached as part of the bull bar mounting supplied by ARB
    I really don't want to have to pull the winch and bar off. That would be a PITA....
