Results 1 to 10 of 11
Thread: Flooded Patrol GQ Turbo Diesel
    Aug 2013
    Hey mates, I'm seeking advice to fix my Patrol GQ 2.8 Turbo Diesel after having tried it as a submarine in a deep puddle. My bad, it's my first 4WD and I went out with some experienced mates who didn't try to stop me from trying that one (I don't have a snorkel on the car - didn't even know I needed one).
    The mech removed the water from the engine, changed all the oils, two filters, charged the battery and let the car dry up for a couple of days...then he managed to start the engine. He also told me that the engine would have some difficulties at the first start of the day for a long time, but it should be fine as soon as the water fully dries up.
    For a couple of days the engine actually struggled starting up, with white smoke coming out the exhaust, but then the troll used to run smoothly.
    ...Until today. Today I cannot start it, no matter how many times I try. White smoke is still coming out of the exhaust and nothing else happens.
    I searched the forum for some similar experience and this is what I found
    FLOODED DIESEL ENGINE
    but I still don't know how could it help me (total rookie).
    Mh, another thing: I'm also experiencing some electrical faults, like some indicators on the dash not working. Better to have a full check at an auto electrician or it might be just a matter of changing/coating with WD40 some fuses?
    Thanks in advance for your help!
    Hardcore the ferret's Avatar
    Sep 2010
    on the coast W.A.
    H mate, the white smoke tells me that the glo plugs are not working, probably due to water in the electricals.
    Might be a good idea to tell us exactly what went on as far as drowning goes, did the ECU get wet, did you try and start it with a guts full of water, you may have bent conrods and this can cause low compression and white smoke also.
    Cheers, the ferret..
    Water and diesel never have a happy ending, Anyway you can dry car with a heater in a confined space
    Aug 2013
    Quote Originally Posted by the ferret View Post
    The car is a '96 model, doesn't have any electronics on it. After it drowned i didn't try to start it anymore, just I've been towed out of the pond and from there to the mechanic, who checked the car the very next day (the fact happened last Sunday).
    Aug 2013
    Yeah I also thought that, the problem is finding a confined space...unless I find a way to stick the troll in the bedroom.
    A mate is suggesting that the alternator might be full of mud, and this would prevent the battery from charging...hence the impossibility to turn it on. What do you reckon?
  6. #6
    Quote Originally Posted by Lokignolo View Post
    If it had a flat battery the engine wouldn't turn over on the starter motor.
  7. #7
    334 Post(s)
    Are you insured? If so call your insurance company, tell them you were crossing a ford in a river and they will write your car off and give you a cheque.
    Sorry not what you want to hear but the best advice I can give you.
    If your insured I'd be making a claim in a heart beat.
  8. #8
    I agree with the above and would be checking for power to the glow plugs, water in the glow plug timer module is a definate possibillity.
  9. #9
    Oct 2011
    Essendon
    .......and get yourself some new mates who don't let you do something like that again! LOL
    Tip tip tip......tap tap tap....
  10. The Following User Says Thank You to Drewboyaus For This Useful Post:
    YNOT (4th August 2013)
  11. #10
    Legendary happygu's Avatar
    Let it sit for a while with the bonnet open, and spray all the electrical connectors with CRC or the like to disperse the water, and see how it goes then.
    Mic
