Page 14 of 30 FirstFirst ... 1213141516 ... LastLast
Results 131 to 140 of 293
Thread: Member on hard times parts list
  1. #131
    does the GU have the provisions for a double din head unit? I got my original Nissan one here not doing anything. I healy wants it...Just a thought.
  2. #132
    Legendary Alitis007's Avatar
    15 Post(s)
    Just making a list of the parts we will need and would like to have for our Member on hard times thread. Theres going to be a wish list or goodies list and a need list that i will be updating as we go along.
    PLEASE ONLY POST HERE IF YOU HAVE PARTS THAT YOU WILL LIKE TO DONATE OR THAT YOU THINK WILL BE A GOOD IDEA FOR THE GOODIES LIST!!
    The car is an 01 GU ZD30 ( Built date 6/2000)
    WHAT IS NEEDED
    GEARBOX / synchromesh kit (4th gear ) - ordered
    Clutch kit - received
    Rear main seal OEM - received
    Rear diff - donated by 4WD Obsession
    Recovery points - donated by Threedogs
    Battery - donated by Mudski
    Oils : Front diff 80w90 up to 5.4 liters -
    Rear diff 140w ( or 85w140) up to 4.7 liters -
    Transfer case TX12A ( 75w90) 1.9 liters -
    Gear box TX12A (75w90 ) 3.5 liters -
    2 X Swivel hub kits and bearings ( bearings felt good but need to look for pitting and metal filings ) - 4WD Obsession
    Rear stabilizer bar link rods, long and short ( 2" lift) -
    Rags, rags, RAGS!!!! And paper towel - Healy, BA
    HTB / High Temp Bearing grease -
    Brake fluid ( DOT 4) - 2 X 500ml -Plasnart
    CV / Constant velocity grease -
    Cable ties, heatshrink, tape and bullet crimp connectors - Winnie
    200 odd adhesive backed cable tie mounts, 2000 cable ties and 30m each of 2 sizes of split conduit - Drewboyaus
    Climate control with cables - ordered
    SAFETY EQUIPMENT
    Jack stands - MR 1 set
    Trolley jacks - MR 2 x 2000kgs jacks
    Wheel chock's -
    Safety glasses - MR has Heaps
    Gloves ?? Leather and silicon / rubber - MR will bring a box of Nitriles (100)
    Hand cleaner ( Good stuff/ Jiff works too) - Alitis007 (i can get some for free but won't be to AB's till late)
    WISH / GOODIES LIST
    To be revealed - Westy's accessories
    Rear work light with mounting stand -
    Rock sliders (the ally side steps look fantastic ATM) -
    Wheel arch flares and rear bar with moulded flares (sorry mate it looks anorexic lol) -
    Spotlights ( who was showing them off the other day ????) -
    Tools
    Like i said i will add more to this list daily!
    Thank you for all your help and support!!
    And a big thank you to Bloodyaussie / Jonathan for organizing this special event!!
    Have i missed anything???
  3. #133
    Hardcore healy's Avatar
    south east melbourne victoria
    Yeah diff oil is sorted its in the garage
    IF ITS NOT BROKEN IT MUST BE A PATROL
  4. The Following User Says Thank You to healy For This Useful Post:
    Alitis007 (26th March 2013)
  5. #134
    Yeah it is but I'm gonna eventually put head unit uhf in that spot thanks for the offer mate
  6. #135
    15 Post(s)
    Quote Originally Posted by healy View Post
    Thanks mate
    Was that front or back can't remember lol
  7. #136
    Both mate ill let you do the others as its cheaper but if you want to slap a bigger turbo and cooler on ill grab the other oils I'm thinking a mild 490 on all 4s will be just fine
  8. #137
    Patrol Guru
    Apr 2011
    Melton
    Let me know if you want anything picked up from brett - im in melton
  9. The Following User Says Thank You to GQ TANK For This Useful Post:
    MudRunnerTD (26th March 2013)
  10. #138
    Thomastown, Melbourne
    6 Post(s)
    One thing I still would like to find is a cargo barrier for the back as he has kids in the car.... of course dont want to pay much???
    Can you see if your contacts have any George???
  11. #139
    Oct 2011
    Essendon
    I'm still working on that one but need to give it a couple more days.
    Tip tip tip......tap tap tap....
  12. #140
    6 Post(s)
    My arc welder will weld non stop to Sydney but is stupidly heavy so if Andy does not have one then Mig/Arc welder would be good!!!!
