Page 58 of 187 FirstFirst ... 5657585960 ... LastLast
Results 571 to 580 of 1862
Thread: MudRunnerTD's GQ From the Ground Up
  1. #571
    22 Post(s)
    The more I see these The more I want some. Do you need 16inch rims to fit?
    96 GQ coil/Cab
    08 G6eT
  2. #572
    Hmmm? Not sure Ben. I think a 15 will fit. Only the 4.8 came out with the larger disk.
    These have much bigger CVs and a wider track and twin pot brakes with much Thicker rotors. Paired with my braided brake lines and this is going to be wicked
  3. #573
    22 Post(s)
    righto. Do you know if 4.8 rotors will fit my h233b? If it can fit it means I can work other things into the budget
    In its current form it hasnt done any long distance drives (+1000km in 1 hit), and if I am doing a trip to landcruiser park or something with alot of dirt road the ute isnt a very nice place to be.
    Im trying to change the setup for the trip next year, so I have to start planning and saving for it now.
    96 GQ coil/Cab
    08 G6eT
  4. #574
    These are diffs off a 4.5 and will take my GQ centres in 4.6s no trouble at all. Straight bolt in. If you grabbed a set off a zd30 you'd get 4.3 centres and your lockers would go straight in. I assume your running 4.6s already though? Although your rock hoppers would probably mean some 4.3s would be sweet.
    Is it only the Ute Cab that is your issue?
  5. #575
    Mar 2013
    Melb, Vic
    Mud runner, your truck is insane!
  6. The Following User Says Thank You to Royce For This Useful Post:
    MudRunnerTD (24th March 2013)
  7. #576
    22 Post(s)
    Sweet I will see what I can find. The compliance plate says I have 4.1's and I havnt changed them.
    The cab is part of the issue due to its size, but the ride is rigid, poor spring and shock choice (although just got back from the first drive with the kings see other thread) and after a while on a dirt road its like I am running leaf springs, its terrible. The base of the recaros have seen better days and need to be beefed up, they'll break your spine after about 6 hours lol
    I'll have it all sorted by next year for meetup in the middle.
    96 GQ coil/Cab
    08 G6eT
  8. #577
    Then chase some GU zd30'diffs and you will get some 4.3s. The GUIV TD42 ran 3.9s so don't think you want to do that. Not sure about the 4.5s although these ones have 3.9s in them. Regardless your 3rd member will just go straight in as a carrier so no big deal.
    Sounds like your setup was wrong. I had the 12 stage Boss and hated them.! Your kings will transform the car. You might look at increasing the pressure for the Meetup touring trip then drop the pressure again when you get home for playing.
    Your running an empty tray most of the time though hey? Loaded for touring will make a difference to mate.
  9. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    Ben-e-boy (24th March 2013)
  10. #578
    22 Post(s)
    We had the same shocks. So I would have encountered similar situations.
    You are right the set up is wrong. the shocks were the first change.
    96 GQ coil/Cab
    08 G6eT
  11. #579
    Well had a big day! George generously gave me a day helping me swap out the front diff in favour of a very tidy braced GU front diff. We swapped out the centre with the Airlocker and its all bolted up. Had a couple of hiccups but looking good.
    Heading over to George's workshop tomorrow to fit Healy's clutch and gear box then back to the GQ on Monday tomgetnthenrear diff swapped over too. No where near as big a job as swapping the front out.
    Cheers George! your a legend mate.
    Alitis007 (30th March 2013)
  13. #580
    22 Post(s)
    Quote Originally Posted by Great Southern Camping View Post
    Top effort mate!! Can't wait to catch up at some stage and do some wheeling - any smell "boys weekend"??!!
    Scotty (Bigrig)
    www.gscoffroad.com.au
    I can smell it. For Sure. Some people say the GQ is an urban myth. I dont believe it at all..... You just need to have a worthy rig to tread the same ground as it. as we both do lmao
    96 GQ coil/Cab
    08 G6eT
  14. The Following 2 Users Say Thank You to Ben-e-boy For This Useful Post:
    Great Southern Camping (30th March 2013), MudRunnerTD (30th March 2013)
