Results 11 to 20 of 23
Thread: Oil light staying on at start up
    Feb 2011
    Shed
    45 Post(s)
    You will need 25,000 posts to download that manual mate....lol
    Should be there in another few months
  2. #12
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Whats that mean?? False reading??
    That's why the oil pressure gauge shows dodgy readings on GQs. Not sure if the warning light runs off that circuit though?
    Tap, crackle, pop
    Hello from Under Down Under!
  3. The Following User Says Thank You to taslucas For This Useful Post:
    growler2058 (4th January 2013)
  4. #13
    Feb 2011
    Shed
    45 Post(s)
    My fancy pants pov pak only has the light, maybe i should go buy some gauges
  5. #14
    99% chance it is the sender. They are very prone to getting grunged up and being slow to see the true pressure however if genuine then low oil pressure is something to be addressed quickly
    Given the cost/complexity of of rrsing about with the pump etc I would def recommend you try a "known" good sender first tho.
  7. #15
    Feb 2011
    Shed
    45 Post(s)
    Cheers mate. My ol girl has been very deep in it on a number of times,so i ll try a new sender. Just checked out the manual for replacing the oil pump and it doesnt look like a 5min job
  8. #16
    Aug 2011
    North West Tas
    56 Post(s)
    Oh it's the POV pack..... Well in that case, just put a bit of black tape over the light. Lmao
    Tap, crackle, pop
  9. The Following 2 Users Say Thank You to taslucas For This Useful Post:
    growler2058 (4th January 2013), MC97GQ (5th January 2013)
  10. #17
    Feb 2011
    Shed
    45 Post(s)
    Tap, crackle, pop
    Wahlla fixed cheers mate.....
  11. #18
    Thomastown, Melbourne
    6 Post(s)
    Ha ha ha ha ha!!!!!
    Yeah that noise I keep hearing.... I got told the problem was the radio was not up loud enough!!!!
  12. The Following 2 Users Say Thank You to Bloodyaussie For This Useful Post:
  13. #19
    North brissy
    Pretty standard for a td42 and oil light to go out in about 5 secs. Oil pump isn't hard to do its only a gear pump. Different filters will take different time as well most these days have an anti drain back in them but they will still lose some oil being mounted horizontally.
  14. The Following User Says Thank You to nissannewby For This Useful Post:
  15. #20
    Feb 2011
    Shed
    45 Post(s)
    It never used to stay on for more than a second or 2 so i was just a lil concerned
