Page 13 of 14 FirstFirst ... 11121314 LastLast
Results 121 to 130 of 139
Thread: Snicko doing the NADS
  1. #121
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    Quote Originally Posted by KRISTOFFA View Post
    That looks like it would suck the crotch out of a low flying duck!
    be great if ya had twin ic,s on
  2. #122
    Patrol Guru Drew's Avatar
    Western burbs of Melbourne
    Quote Originally Posted by roofy View Post
    Not if you're the duck...or flock in that case
    I think I missed it, which scoop is that ?
    2008 GU 3.0 CRD Auto - Life's too short to eat bad food.
  3. #123
    go back 6-7 posts
  4. #124
    I think he's referring to. Where did you get that scoop? As I'm keen to know aswell. Something i need to do before summer hits. That and a thermo fan for it.
  5. #125
    Been thinking of a thermo fan, asked the question here before and most were of the opinion
    not really worth it. MUDSKI I'll PM where to get the scoop not far from you.
    A fair bit of work has gone into these scoops, they are designed by a Turbo freak.
    The internal vanes direct air to the front of the IC, where as an OE scoop all air goes to the rear of IC.
    Meaning this IC will work at a lower speed possibly around the 60kph mark, where an OE
    does nothing till 80KPH.
    bullbars redirect the air, ever seen a moth or similar go into the IC ??????
    This same person, turns your vacuum turbo into a pressure system there for eliminating
    Dawes and needle valve, boost and EGT guage still required
  6. #126
    Psst pm me too pls
  7. #127
    Thanks for the info mate. I think for the price of a thermo fan, it wont hurt to try one. As for converting the Turbo from vacuum to pressure. I heard thats quite expensive and using a dawes and needle valve seems to work well anyway...
  8. #128
    Aug 2011
    Kellyville, Sydney
    I'd be interested in where to get that scoop as well.
  9. #129
    Bannockburn
    Thanks Mudski, I get most of what you've written but whats Dependable disty's in Adelaide, and do you have a website or something to check out your Dawes Valves for sale, thanks heaps for your advice., Also is there somewhere on the forum that shows from A-Z the fitting of all these things? The post from Snicko is pretty good, just wondering if there were any others? Thanks again
    If its the 3ltr then yes you need to NAD up.
    What you will need :
    * Dawes : From the US or me, I'm a bit dearer but its a lot quicker
    * Needle Valve : Dependable disty's in Adelaide
    * Provent 200 catch can : Ebay The $170 priced one.
    * EGR Plate : The Ferret does'em
    * Pyro bung : Zorst shop
    * assorted hose and fittings : Hose shop
    * Boost and EGT guage (this needs to be fitted before anything) : Anywhere you fancy
  10. #130
    Quote Originally Posted by Forest1970 View Post
    Sorry. Dependable Distributors they are called. Disty for short. The Dawes valve I do sell myself but I have ran out. I sold 10 in 9 days, quicker than i thought. Five on Ebay and five through word of mouth. I have more coming but it wont be for atleast a week or two I reckon. I am dearer than getting it from the states but when I had them, you would get it much quicker that waiting for it to come from the US. I'm in the process of a fully adjustable Dawes type valve which has a screw cap on it to adjust it, rather than using two spanners...
    Which fittings are you referring too? The fittings for the Catch can? Or everything? What model Troll do you have aswell? I'm happy to help you out where I can.
    Food for thought, the gauge I have is from McNally Electronics. Its an electronic boost gauge with with a digital EGT read out on the same gauge. Sits nicely right in between the speedo and tacho.
    http://www.mcnallyelectronics.com/
    Derrr! Don't mind me. been a hard day at work today. The fittings you asked about, you want to know how to fit it all.
    First thing to do is get the gauge and installed. As you need to see whats going on when you fit everything else. Getting the pyro fitting in the dump pipe is the biggest pain for the whole job as you need to remove this pipe, so this means having the truck off the road whilst you get this done.
    Then you continue with the rest...
