Page 3 of 9 FirstFirst 12345 ... LastLast
Results 21 to 30 of 82
Thread: The GQ!
  1. #21
    Sunshine Coast, QLD
    your gonna go for the 4" suspension lift?? what state are you from??
  2. #22
    Sep 2011
    Quote Originally Posted by BLKWDW View Post
    Alright got a quote on a 4inch lift from opposite lock. This was bout 4k all up. I noticed it doesnt include drop boxes will i still need them?
    2 BMX1047/4 Tough Dog 45mm Adjustable $550.00
    Shock Absorbers 4&5' lift Front
    $275.00 EA GST 2 BMX1206/4 Tough Dog 45mm Adjustable $550.00
    Shock Absorbers 4&5' lift Rear
    $275.00 EA GST 2 TDC734/4H Tough Dog 4'' Lift Coils $160.00 EA $320.00 GST 2 TDC732/4 Tough Dog Coil springs GQ GU $320.00
    4" REAR up to 300kg
    $160.00 GST 1 / steering damper adjustable or $300.00
    return to centre
    $300.00 EA N-T 1 TDUK-041 Urethane Bush Kit Radius rod to $65.00
    chassis
    $65.00 Kit GST 1 TDUK-050 Urethane Bush Kit Radius rod to $185.00
    diff
    $185.00 Kit GST TDUK-051 Urethane Bush Kit Panhard rod $65.00 Kit GST 2 TDUK-052 Urethane Bush Kit Radius rod to $300.00
    chassis
    $150.00 Kit GST 1 TDUK-054/3 Urethane Bush Kit Castor $230.00
    bushes 3 degree
    $230.00 Kit GST 1.5 FCLA press out castor bushes /press $142.50
    in new offset castor bushes
    $95.00 EA GST 1 TDSP-004/2 Transmission Spacer suit coils $110.00
    spring vehicles
    $110.00 Kit GST 1 TDBH-001 Tough Dog brake hose kit suit $120.00
    big lift in Nissan Patrol
    $120.00 PR GST 1 FCSC Fitting - Suspension System 4 x $255.00
    Coil Springs & Shocks
    $255.00 0 GST 1 TDPR-004 Adjustable Panhard Rod Front $260.00 Kit $260.00 GST 1 TDPR-005 Adjustable Panhard Rod Rear $260.00 Kit $260.00 GST
    This is also a kit from superior engineering for $3500.
    2 x Coil springs front
    2 x Coil springs rear
    2 x Front 45mm Tough dog Big Bore Adjustable shocks (BMX1047/6)
    2 x Rear 45mm Tough dog Big Bore Adjustable shocks (BMX1206/6)
    1 x Tough dog EXT Steering damper (EXT5000)
    1 x Front adjustable panhard rod
    1 x Rear adjustable Panard rods
    2 x Drop box's (Instructions)
    2 x Extended brake lines
    1 x Extended diff breather kit
    1 x Extended brake proportioning valve bracket
    2 x Lower control arms
    1 x 4140 H/D adjustable Drag Link
    2 x Coil drop out cones
    2 x Coil retainers
    2 x Damper brackets.
    What are peoples thoughts.
    This is my advice mate, steer clear of the return to centre steering dampner they only put more pressure on your other steering components, you have been quoted with castor bushes so no drop boxes needed. You really want to use standard nissan rubber bushes and drop boxes instead of the castor bushes though. Also get rid of all those poly bushes they want you to buy. There really is no replacement for genuine rubber bushes in all cases. I doubt you need all those bushes to be replaced either. Transmission spacer is not required either. Personally I'd stay away from the shop that is trying to flog all that gear off to you. Also superior engineering gear is excellent stuff but a little pricey.
  3. #23
    Quote Originally Posted by Micktroll View Post
    NSW.
    Quote Originally Posted by BigMav View Post
    Yeh well the superior engineering one is $500 cheaper.
  4. #24
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    I would go Superior Engineering over Opposite Lock, which ever one you chose, go drop boxes over castor correction for a 4" lift
    Darren, I think I have said this 2 you already, but please Ring the RTA Technical first and see what you legally need to do to have this mod. I believe you still only need and engineers certificate.
    Todd
  5. #25
    All that is needed is an engineers certificate.Rang them this morning
  6. #26
    Feb 2012
    Nth QLD
    Look forward to seeing the after lift photo's
  7. #27
    hey mate what have you done with the roof racks/bars??
    there just sitting in my shed mate why you keen for them. If you pay for freight you can have them. there ugly as.
  8. #28
    The lift is waiting till tax time know as i used that money to buy the kids some motorbikes to take away with us and i can carry them in the new trailer i got to tow behind the gq.
    Some larger tyres and front locker will get me most places i need to go. The 60 is sold and will get half the money this week and the rest in a fortnite so the mods will soon start. Can get a spartan autolocker from locktup 4x4 for $485 but seen them on ebay for much less but will this fit? http://www.ebay.com.au/itm/Spartan-L...ht_2000wt_1397
    Tyres will be first. I can get a set of 35's for my patrol for a similar price as new 33's. is it worth getting the larger tyres with a near standard car and not much lift?
  9. #29
    trailer looks the biz mate...... me personally, I'd go with the 33's
  10. #30
    RIP - valued member and true gentleman of this forum that will be missed by many! Silver's Avatar
    Feb 2011
    Brisvegas
    If you are going to sell the 2" kit, I'd be interested :-)
    Rick
    "As a boat owner and a four wheel drive owner I feel like a pelican: every where I look I see a big bill in front of me”
