Page 1 of 7 123 ... LastLast
Results 1 to 10 of 65
Thread: Warn Winch Service Manuals 6k to 12k
    Feb 2012
    "Hiding Under Your Bed!"
    30 Post(s)
    Here are some links to the service manuals for WARN Winches 6k to 12.
    Cheers to AB for loading them for us so there are available to everyone.
    http://www.nissanpatrol.com.au/warn-...k-8k-xd9-1.pdf
    http://www.nissanpatrol.com.au/warn-manual-9k-12k-1.pdf
    www.swat4x4.com
  2. The Following 9 Users Say Thank You to oncedisturbed For This Useful Post:
    dads tractor (1st February 2013), davo94 (23rd July 2012), Drew (24th July 2012), growler2058 (17th February 2012), MudRunnerTD (17th February 2012), NissanGQ4.2 (17th February 2012), threedogs (1st September 2016), Warwick89 (18th July 2016), Woof (19th June 2012)
    Awesome! Thank you
    Quote Originally Posted by oncedisturbed View Post
    http://www.nissanpatrol.com.au/warn-...-6k-8k-xd9.pdf
    http://www.nissanpatrol.com.au/warn-manual-9k-12k.pdf
    Thanks very much for these . I think I have one of these on my HD
    Can anyone find anything like this for Warn M10000 ??
    Feb 2012
    30 Post(s)
    It looks like that particular winch is no longer made by Warn Industries, this is the best I have been able to find on them
    http://warnserviceparts.com/m10000.asp
    http://www.doc-txt.com/Warn-Winch-manual.pdf
    www.swat4x4.com
    Perth WA
    63 Post(s)
    Well done mate, thanks again
    Jul 2012
    Thanks for the above info.
    Looks like im i strife as the head size is 16 or 17mm square, bolt dia 10mm.
    I do recall that they were square headed bolts in this winch which i have had for a long time.
    Near enough to 20 years i would think.
    Ill get some 10mm bolts and rebuild the head to suit the T slot.
    The other concern i have is, i had this winch mounted to the inside of an 8 inch channel bull bar home made and never bent, trees and all.
    It was that heavy i had to up grade the springs in the gutlux.
    The winch was mounted against the inside of the channel and a direct pull against the T bolts.
    So the forces were in a straight line against the mounting housing.
    It is now going to be mounted 90 deg to the mounting points in the cradle.
    My concern is will it break under strain as the mounting brackets are only ally?
    I would hate to find out the hard way in the middle of no where.
    In any case thanks for the above info.
    Cheers.
    South Africa
    The manuals are great. Next question, where can I find a really good winch operating guide. Do's and don'ts not only for safety but also operation and general maintenance, cable winding techniques, etc.
    South Africa
    Mmmm, must be having a slow night. After posting this have just tripped over a basic guide to winching techniques in another thread.
  10. #9
    Jul 2012
    Thank You!
  11. #10
    Quote Originally Posted by Conradk View Post
    Sorry Conrad, I know we are way way too late but you hit this at 6am back then local time and obviously got lost n the soup. Thread just been bumped so I figure might as well embed the thread you need with all the safety info you need for winch recovery.
    Stay Safe, Play Safe THINK
    Recovery-The-Fundamentals
