Results 1 to 10 of 11
Thread: tacho signal wire in gq 1993 tb42
    Beginner 304troll's Avatar
    Jul 2011
    millicent SA
    Question tacho signal wire in gq 1993 tb42
    Hi everyone does any one know the colour of the wire that connects to the tacho either in the dash or at the computer plug of a GQ patrol 1993 as i have done an engine conversion and want to hook the tacho back up so i need the wire colour/location to hook the interface signal converter
    vehicle was a (tb42 EFI) now converted to a holden 5 litre
    just want some form of idea how hard im pushin my rig
    Cheers heaps for the help
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    This should help
    Todd
  3. The Following User Says Thank You to NissanGQ4.2 For This Useful Post:
    304troll (27th November 2011)
    Jul 2011
    millicent SA
    Todd my friend you are a bloody champion cheers bro if ya ever around millicent sa hook me up so i can buy ya a beer or somethin
    Aug 2010
    17 Post(s)
    Quote Originally Posted by 304troll View Post
    No worries, I'm guessing that diagram helped you out?
    Jul 2011
    millicent SA
    Yeah man did the trick might even get enthusiastic and rig up the oil pressure gauge now lol
    Aug 2010
    17 Post(s)
    Don't get 2 carried away *L*
  8. The Following User Says Thank You to NissanGQ4.2 For This Useful Post:
    PeeBee (23rd February 2025)
    eddietrx
    Guest
    The standard tacho will not be accurate as it is for a 6 and not an 8
  10. #8
    Feb 2025
    This should help
    Todd
    Gday I know this is an old thread but if I was to be running a carby set up could I take that yellow and black wire from the ecu plug and put it to the negative side of the coil for the tacho to work
  11. #9
    84 Post(s)
    [QUOTE=Kingrobert98;849598]Gday I know this is an old thread but if I was to be running a carby set up could I take that yellow and black wire from the ecu plug and put it to the negative side of the coil for the tacho to work[/QUOTE
    You will need to establish if the ECM ( engine control module) is still providing a viable signal. The TB42S (carby) gets a signal from the coil or some use an engine revolution sensor to provide that signal. Maybe you can obtain a carby tacho, swap it out of the gauge cluster and rewire it to the coil.
    Download the workshop manuals to see what works for you.
  12. The Following User Says Thank You to mudnut For This Useful Post:
  13. #10
    Feb 2025
    [QUOTE=mudnut;849604]
    Quote Originally Posted by Kingrobert98 View Post
    Thanks for the reply mate I’ll look into the carby tacho. Have you any idea where the ecu for the tb42e gets the signal to send to the tacho.
