View Poll Results: Can You Attend?? Are you Good With??
Voters
17. You may not vote on this poll
  • Attending - Yes - Either Saturday is good for me
    4 23.53%
  • Attending - Yes - Saturday 24th September
    1 5.88%
  • Attending - Yes - Saturday 8th October
    8 47.06%
  • Attending - No - Simply can't make it - sorry lads!!!
    2 11.76%
  • Attending - No - I'm as yellow as a custard factory and am afraid to ask!!
    2 11.76%
  • Good With - Engine and Mechanical
    8 47.06%
  • Good With - Auto Electrics
    6 35.29%
  • Good With - Transmission/Transfer Case etc
    3 17.65%
  • Good With - Suspension
    9 52.94%
  • Good With - Assorted Other
    10 58.82%
  • Good With - Beer Opening Only
    4 23.53%
  • Good With - BBQ'ing Extraordinaire
    4 23.53%
Multiple Choice Poll.
Page 17 of 29 FirstFirst ... 1516171819 ... LastLast
Results 161 to 170 of 284
Thread: QLD Members Working Bee - Expression of Interest
  1. #161
    Hardcore macca86's Avatar
    Jun 2011
    Brisbane again! whoo!
    here's an example
    Attached Files Attached Files
    Such is the rule of honour.
  2. #162
    22 Post(s)
    Quote Originally Posted by macca86 View Post
    You have to work to the mean of all your bends and plus or minus for your length
    so if that is the case if i do 2 90 degree bends it would be 90/2= 45mm + or-
    96 GQ coil/Cab
    08 G6eT
  3. #163
    22 Post(s)
    here's an example
    I replied before I saw this
    I understand now
    96 GQ coil/Cab
    08 G6eT
  4. The Following User Says Thank You to Ben-e-boy For This Useful Post:
    macca86 (28th September 2011)
  5. #164
    Jun 2011
    check the pdf I posted for a diagram so the long middle piece in between the 2 bends will be minus the width of the section you are using and the two bit off the 90 degree bends would be minus half the thickness of the section used. I'd allow 10 to 20 mm green on the leg lengths off the 2 90degree bends and cut back to suit.
    hope this helps
  6. The Following User Says Thank You to macca86 For This Useful Post:
    Ben-e-boy (28th September 2011)
  7. #165
    Jun 2011
    you can cheat too. you can buy pre bent elbows and just square cut everything and weld together but bending may be cheaper if you have a bender
  8. #166
    Simpson Desert GUtsy ute's Avatar
    Apr 2011
    Forestdale Brisbane
    [QUOTE=beansathome;146055]im really thinking about making my own rear bar and sliders i might invest in a cheep bender from supper cheep or something and give it a go. i have no problem wih welding and grinding i recon i couuld make them look prety.
    Don't bother buying a cheap pipe bender, the dies don't work with the chinese pipe you are sold these days.
    I have got one with reasonable dies I bought quite a few years ago you can use at the working bee
    if you like.
    It still doesn't do a nice bend on the pipe you get these days, it almost has to be mandrel bend to get a
    nice radius.
    Someone mentioned the price of dies that work and for a one off item not worth it. IMHO.
  9. #167
    22 Post(s)
    Yeah I get it cheers.
    Hopefully for the next few weeks i'll be covering shift at a mill that runs quite smoothly and not many breakdowns so I can have some time to practice on the press and benders
    96 GQ coil/Cab
    08 G6eT
  10. #168
    22 Post(s)
    [QUOTE=GUtsy ute;146814]
    Quote Originally Posted by beansathome View Post
    if you like.
    nice radius.
    Yeah that was me. I priced some dies and nearly fell over when I saw the price. I could of bought a few benders for the price
    96 GQ coil/Cab
    08 G6eT
  11. The Following User Says Thank You to Ben-e-boy For This Useful Post:
    GUtsy ute (28th September 2011)
  12. #169
    Expert beansathome's Avatar
    Nov 2010
    deception bay (QLD)
    if you like.
    nice radius.
    im not to fussed on the perfact looking bend all i want be stronger then the standard side step . i hope i can make it to the working bee all i want to do is get the bends in it not build them i can do that part at home
    but i think this should be a seprate day as this does sound like a big job if to many people want to get on the pipe bender
  13. #170
    Banned Bigrig's Avatar
    Oct 2010
    South of Brissy, QLD
    [QUOTE=beansathome;146890]
    Quote Originally Posted by GUtsy ute View Post
    Separate day sounds the go, as I want to re-do my back bar now also, so it looks like between us all, we have a good days bending and welding.
