Results 1 to 4 of 4
Thread: NISSAN PATROL Y60 GQ Fuel Pressure Test
    Dec 2022
    Question NISSAN PATROL Y60 GQ Fuel Pressure Test
    Anyone know how to attach a fuel pressure gauge to the fuel rail on a NISSAN PATROL Y60 GQ
  2. The Following User Says Thank You to psimpson3995 For This Useful Post:
    MB (3rd December 2022)
    Apr 2021
    Brazil
    AI answer, LOL.
  4. The Following 2 Users Say Thank You to BrazilianY60 For This Useful Post:
    MB (5th April 2024), Touses (6th April 2024)
    Expert Arfa Brayne's Avatar
    Jul 2016
    AI answer, LOL.
    Yeah - ha ha.
    Plain english, aussie bloke/shed method.
    On the end of the hose that goes from the fuel filter to the engine, temporarily fit a 3/8" (8mm) brass tee and an extra bit of fuel hose to continue to the motor.
    Using another bit of fuel hose off the leg of the tee, connect to a fuel pressure gauge that will handle at least 80psi.
    Now when you run the engine, the fuel pressure gauge will show the pressure in the rail as supplied by the fuel pump and controlled by the fuel pressure regulator on the outlet side (tank return) of the fuel rail.
    Fuel pressure should be around 40psi at idle, and climb to around 55psi at full load. This is because the fuel pressure regulator adjusts pressure to compensate for manifold vacuum.
    "Can't" is a dirty 4 letter word.
    Best way to deal with a "Can't" is to chop off the "t" and brew it in boiled water for a few minutes.
    Sip on the "t", and consider what you've got left to work with
  6. The Following 2 Users Say Thank You to Arfa Brayne For This Useful Post:
  7. #4
    Nov 2019
    Perth
    5 Post(s)
    Quote Originally Posted by williamrhone View Post
    Attach the appropriate fittings or adapters to the fuel pressure gauge based on the specifications of your Nissan Patrol Y60 GQ. Connect the fuel pressure gauge to the test port on the fuel rail. Ensure a secure connection.
    minecraftle game
    Why the link to Minecraft?
    2008 CRD Auto Wagon
