Any particular reason for the adjustable panhard bars be tapered on one and only with the other end fixed/welded? The way I imagine, if you build it tapered both ends (so with an "floating" adjustable section) you could adjust the track position without taking the panhard chassis end out, which is a pain to put back when misaligned.
