Results 1 to 10 of 16
Thread: Engine bay relays identification GQ TB42 Manual
    Nov 2022
    Melbourne VIC
    Hi all. Recently bought a 1994 GQ TB42 Manual with EFI and gas conversion. Currently tidying up the engine bay. Hoping someone can tell me about the relays in the engine bay next to the battery under the black cover.
    Specifically interested in the ones circled in the pic. Top right corner brown relay, unused blue relay socket and the blue relay mounted to the guard with the silver wire wrap.
    thanks heaps. Everything seems to be working fine but just curious for future reference before I put everything back together.
    Nov 2022
    Melbourne VIC
    I forgot to mention there is no power windows on the car or rear a/c. it is an RX model. thanks
    May 2022
    Tai Tokerau, RD8
    15 Post(s)
    Have an assistant turn the key from "OFF" to "ACC" and feel (finger on relay cover) which ones -click-. Then do the same with key from "ACC" to "ON"... will narrow it down for you.
    Or just pull the relays out and see what stops working?
    1989 LWB 5-Seat, TD42
  4. The Following User Says Thank You to mihit For This Useful Post:
    MB (6th December 2022)
    May 2022
    Tai Tokerau, RD8
    15 Post(s)
    There will be a colour-coded wiring diagram in a manual, somewhere, too.
    Nov 2022
    Melbourne VIC
    thanks. i will give that a go. Given it is a manual i had ruled out the Park/Neutral no start relay, no power windows, no rear a/c. ATP / PTC heater also seemed unlikely given some googling to understand what this could be. I will see if I can access a manual. Thanks for responding @mihit
    May 2022
    Tai Tokerau, RD8
    15 Post(s)
    I've got my haynes manual handy...if you tell us what colour wires go to the relays I can tell you what it reckons...
  8. #7
    Nov 2022
    Melbourne VIC
    Merry Christmas all ... thanks @mihit.
    details and pics below
    First pic is the harness plug that is upstream from the blank Blue Relay Socket and the Brown Relay.
    Input wires:
    - White with sky blue stripe
    - Sky Blue
    - Purple
    - White with Red Stripe
    - White with black stripe
    Output (these lead to the relays in question .. downstream)
    - Red
    - white with black stripe
    - white with red stripe
    - white with sky blue stripe
    - Purple
    - sky-blue with red stripe
  9. #8
    Nov 2022
    Melbourne VIC
    Nov 2022
    Melbourne VIC
    now for the Brown Relay:
    - yellow with red stripe
    - black
    - red
  11. #10
    Nov 2022
    Melbourne VIC
    Now the Blue Empty relay socket:
    - Orange with Blue stripe
    - Blue with red stripe
    - purple
    Empty-Blue-Socket-Wires-2.jpgEmpty-Blue-Socket-wires-3.jpgEmpty-Blue-Socket-wires.jpg
