Results 1 to 7 of 7
Thread: Y61 4.8 Fuse box engine bay.
    Trinidad. W.I.
    Hi all,
    I just bought a y61 4.8 at an auction. Its pretty well butchered by the last owner (Government / Ministry) Engine wise. Body an Suspension is in good order. Interior looks like something was living it it for a few years.
    I will be doing a LQ4 with 4L65E conversion in it.
    The Engine was used for parts and they took out all the fuses and relays.
    Does any one with a 4.8 have a picture of the engine bay fues box, so I can see what goes where?
    Also are the relays universal across the nissan platform?
    Expert Skitzyrex's Avatar
    Jul 2013
    Not sure about the relay question however I can take a pic of the fuse and both relay boxes in the morning if you like.
    2007 GU ST-S 4.8 Patrol.
    40mm heavy duty springs, Dual batteries,
    140 ltr fuel tank,Custom 60ltr water tank, draws, cargo barrier, bull bar, IPF spotties, UHF.
  4. The Following User Says Thank You to Skitzyrex For This Useful Post:
    Bigcol (25th September 2016)
    Trinidad. W.I.
    Thanks that will be great.
    Jul 2013
    Here what's under my 07 4.8
    The fuse box.
    Drivers side relay box
    Passenger side relay box
    Trinidad. W.I.
    Thanks again, this will help a lot.
    Now just to figure out where to get all those relays.
    Mar 2020
    Hi Mate,
    I have recently obtained a vehicle with this fuse box under the hood. From another post I learned I have to replace a 10 amp fuse in here, but I have not been able to remove the lid without breaking the flimsy plastic, any clues as to releasing the catch holding it on would be appreciated.
    465 Post(s)
    Quote Originally Posted by KeepRolling View Post
    Hi Mate,
    stick a flat bladed screw driver in where the clip is, twist the screwdriver and pull the lid at the same time.
