Results 1 to 6 of 6
Thread: Air Con Leaking water to inside of vehicle
    Oct 2015
    Mid North Coast
    Bobin 51 here
    We a travelling and the Air Con is leaking water to the passenger side of the vehicle. Anyone had this problem or has anyone got a suggestion why this may be happening? 2004 Gu Patrol
    Thanks in advance for replies
    195 Post(s)
    Hey mate, usually the little drain hose has come off the bottom of the box or it is blocked and filling up and leaking. Check hose at bottom of heater box under the glove box will be a little right angle hose that goes through firewall. Check its connected if not plug back in if it is pull it off and poke a stick up the hole to unblock just watch a heap of water could come out lol. .
    Oct 2015
    Mid North Coast
    Thanks Rossco
    We have just arrived in Mackay and will try that fix tomorrow Hope that it is just a blockage .
    469 Post(s)
    It will be a blockage more than likely as old mate mate said. Either that or the drain hose has come off.
    Expert Truckus's Avatar
    Feb 2021
    Central Coast NSW
    Or you could plumb it to a water tank....you making water there, ...guessing Mackay is very humid right now!
    2005 Y61 GU rebuilt 2020. 6.5 L turbo inter-cooled Diesel, SupENG Superflex 4 Inch Lift Kit 2,0 Remote res Fox shocks, offset trunions, 315/75/16 Maxxis Razr, 16 x 8 steel rims, SupENG drop box, Stedi Spots & bars, 12000 lbs winch,rear locking bars with duel tire carriers, 4” XtremeENG S/S snorkel, rock sliders, SME UHF, ARB Hard mount Air compressor, ARB fwd & rear air lockers,Rhino roof racks, Duel battery set up, 12 V dist swbd ,
  6. #6
    Patrol God Stropp's Avatar
    34 Post(s)
    My brother bought my old patrol and the exhaust flange came loose and the exhaust dropped and melted that tube shut and filled the car with water
