Page 988 of 1056 FirstFirst ... 986987988989990 ... LastLast
Results 9,871 to 9,880 of 10560
  1. #9871
    I am sorry to find Gentlemen but have stuck this OEM dirty rubber nipple in my gob and truly vacuum sucked as hard as a bong smoking pot fiend could possibly do to no avail trying to close this suckers lips up safely for crud sucking potential
    Unfortunately too Daz the rising inner tube wicked solution will struggle to work I believe for this specific airboxes position/scenario found as there is zero swing/elevation room for the tail end to complete its cutoff mission under swamping.
    Have started plumbing up a fully sealed system with an old school manual drain that should sump/pipe snorkel splash collect up to a calculated 0.5L before the external lowest release valve to come needs releasing
    Have tried to replicate the rubber OEM nipples sump (floor level) slots as best as possible and truly appears now the last dregs drains faster out too as it has 50% more holes (4 slots versus 6 hexagonal holes)
  2. The Following 2 Users Say Thank You to MB For This Useful Post:
    Rossco (7th February 2021), rusty_nail (7th February 2021)
  3. #9872
    195 Post(s)
    Oh wow, took me a while to work it out (the little holes bit) very nicely done
    Yeah do like Millwelds way of doing it, I just leave the tap closed all the time and only open after driving in pretty crazy storm and usually only get a little out. . Just good peace of mind to know it's 100% sealed I reckon. .
  4. The Following User Says Thank You to Rossco For This Useful Post:
    MB (7th February 2021)
  5. #9873
    Whatcha think of this wacky airbox drain idea @Rossco Mate
    Bought a plumbers one-way check valve on the way home from work:
    Drilled a tiny hole in the end of its outlet shaft:
    A mini brass eyelet screw in the end and a pair of nipple rings attached:
    Give her a tug and she squirts all over the place:
    Think I’ll keep it manually activated from outdoors if needed but in theory comp truck blokes could add on an old school choke cable system to activate an emergency drain whilst on the racing fly maybe
    Rossco (9th February 2021)
  7. #9874
    GQ high mount gardening
  8. The Following 5 Users Say Thank You to Winnie For This Useful Post:
    10G (9th February 2021), Hodge (9th February 2021), jack (8th February 2021), MB (8th February 2021), TPC (9th February 2021)
  9. #9875
    109 Post(s)
    Haha mate that stuff's a bitch! I hacked mine out by hand 5 years ago and it was neverending hacking and here you are doing it in 10 minutes beer in hand I did have a bit more than you tho!
  10. The Following User Says Thank You to Plasnart For This Useful Post:
  11. #9876
    Nice work Chrisso Mate
    Before you get safety flamed, I can see you’re carefully just rolling the weed matting back and lightly popping the shrubs very shallow roots easily.
    My honest question is though, how on earth did you connect your hook to the weed matting without ripping through in milliseconds ?
    Some sort of graspy clampy useful thingy?
  12. #9877
    The pics make me seem much more smarterer than I truly are.
    I hooked around the base of the hedges and it pulled the matting with it
  13. The Following 3 Users Say Thank You to Winnie For This Useful Post:
    MB (8th February 2021), Rossco (9th February 2021), rusty_nail (8th February 2021)
  14. #9878
    Lazy mans hooker hoe, it still worked a treat by the look of it Mate
  15. #9879
    Yeah made short work of it. We are all ready for the builder to come in and get started on our deck pergola in 2 weeks. Very exciting!
  16. The Following 2 Users Say Thank You to Winnie For This Useful Post:
    MB (8th February 2021), rusty_nail (8th February 2021)
  17. #9880
    Perfect spot chosen too Mate!
    Life gets brilliant when you can easily/quickly step between the Mrs kitchen and your wicked Mr tucker smoker contraption outdoors area without needing to poncho up with umbrellas over meat trays in the rain ☔️
  18. The Following User Says Thank You to MB For This Useful Post:
    Winnie (8th February 2021)
