Hi all,
Having a bit of an interesting issue with the GQ RB30, I'm hoping someone may have had occur to them or may know what's the cause..
The car stalls / seems to run out of fuel when starting on a hill and taking off after being left for the day. Is reluctant to then start again until on flat ground.
I have changed the fuel filter, cleaned the inline fuel mesh on the banjo bolt On the carby and I have tested the return fuel solinoid resistance.
I first thought that the float may be stuck in the carby but lately the car has recently began stalling shortly after been refueled.
I have noticed a lot of pressure being released when removing the fuel cap.
Is it simply the fuel pump can't keep up and is too weak to get pressure back in the tank / lines?
Is there any other componet I'm missing here?
Cheers in advance..
