15th September 2018, 06:42 PM
Weird draining? Radiator
So lads dropped the coolant then topped it up and it only took 5ls? What is the deal it’s a 4.2td I heard it holds 13l I heated it up and level still is at full where’s the other 8 or so litres
15th September 2018 06:42 PM
15th September 2018, 06:52 PM
Is it bled properly? And more so, did you drain the whole system, there is a fair bit of coolant in the block which is a c*** to fully drain.
15th September 2018, 06:59 PM
Shouldn’t it filter back thru as block is heated up?
15th September 2018, 07:07 PM
Because when I reopened cap after driving it the coolant looked the same as when I put it in, you think it’d be different as if it cycled through the block if the other litres hadn’t come out if you understand what I’m saying hard to explain. Hope I’m making sense
16th September 2018, 07:38 AM
Only draining the rad just pretty much just that. There will still be a lot of coolant in the engine block. There is a drain plug on the block too, but I've never bothered on mine. I dont even know where it is TBH.
16th September 2018, 07:41 AM
mudski
It's on the passenger side behind the dump pipe. It is an absolute c*** b*** to get to.
mudski (16th September 2018)
16th September 2018, 07:44 AM
Drifty3@hotmail.com
It is possible, the thermostat isn't opening and cycling maybe? Sounds strange.
Where did you drain from originally?
16th September 2018, 02:55 PM
Bottom of radiator I think it cycled today took it for like 150km drive must take a lot to get it to cycle I got it up to half temp yesterday aswell. I thought they’d cycle soon as half temp obv not they take sustained temp at half
