Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: I need help with a whirring noise
    Feb 2017
    https://youtu.be/X9FtPPSTk4E
    Heres a link to hear sound
  2. #12
    Expert the godfather's Avatar
    Mar 2011
    Piara Waters, WA
    IS it only under hard acceleration or load? Or does it do it at the same revs when cruising?
  3. #13
    Feb 2017
    It does it more when just cruising light acceleration. If I put my foot down it stops
  4. #14
    Feb 2017
    Went to mechanic today he said could be cutch fan hub it did have a little play in it ,
    That what gqtdauto said to
    I’ll find out Friday when Intercooler and clutch fan comes in thanks
  5. #15
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Quote Originally Posted by Pete6565 View Post
    Mate that's one weird arse scream it almost sounds like those screaming goats , I'm not confident it's the fan clutch and thinking more turbo , my idler rollers for the fan belt occasionally one of them makes a noise but not like that .
    I see what you mean about it doing it while under acceleration but also backing off .
  6. #16
    Feb 2017
    Mate I’ve changed turbo , intercooler , clutch fan I’m starting to think is it a pulley belt alternator
    I’ve replaced the tensioner pulley 50000kms Ago
    I just can’t put my finger on the problem
  7. #17
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Worth checking I suppose it doesn't sound like an alternator but I've been caught before , is it still putting out 14.3-4 volts
    Wondering if it's possible to disconnect the fan belts and go for a quick spin to see if the noise is still there , maybe someone here knows if that's possible without causing damage .
  8. #18
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    If its alternator, it may change in pitch under load. Maybe turn the lights and aircon on and fond see if the pitch change. Idler pulley?
