Results 1 to 10 of 18
Thread: TD42 rebuild time
    SkippyGU JackCollo's Avatar
    Dec 2016
    Melbourne VIC for now
    TD42 rebuild time
    Hi everyone
    The time has come for me to begin the strenuous and exhausting task of rebuilding the old TD42 I have sitting in the garage. It came out of an old gq non turbo. This being said I need your guys help to get brands for all the bits and pieces for the build.
    Things I know I’m getting are
    Borgwarner turbo
    12mm pump
    CC intercooler
    Fatz fab air box
    Patroldocta snorkel
    What I need help with is stuff to do with the motor itself.
    Ceramic coated internals
    Heavy duty internals
    New ceramic sleeves
    Etc basically the strongest internals around.
    Throw some names at me and I’ll investigate.
    Jack
    Currently own a ZD30 2000 GU patrol with a dead injector pump about to start a build on a TD42 motor to go in the car and basically rebuild the whole car into a machine of a rig
  2. The Following 3 Users Say Thank You to JackCollo For This Useful Post:
    AB (25th September 2017), gubigfish (25th September 2017), Rossco (25th September 2017)
    587 Post(s)
    Yeah wow, going the full hog mate, awesome!
    Hopefully Matty and bennyboy can offer internal advise here.
    keep us posted with the build mate!
    469 Post(s)
    I purchased the engine kit for my TD from Engines Australia in Dandenong. It was their top kit with ceramic coasted pistons and the best in quality of everything. I can't remember the exact details on the build but I had different exhaust valves used and different valve springs. If you need a new head, genuine is the best but they are hard to come by lately so im not sure what the next best in that regard.
    Other bolts ons you will need is
    • Engine loom, I sent mine to Killa Kustoms, came back all done an with some tacho jigger so the tacho would work.
    • TD42 crossmember. Mounts the gearbox about 10mm forward, so the TD doesnt rub on the firewall
    • TD engine mounts and chassis plates
    • Acc pedal and cable
    • Fuel filter head, you can use the ZD one though
    • Radiator, again, you can use the ZD radiator setup
    • Clutch
    Air box. I have the Fatz Fab box but when I can afford it will be changing it out for a custom box that uses a flat paper filter. Im not convinced the K & N style pod filter is filtering as good as a paper filter. That statement will probably open a can of worms...
    Snorkel, just dont get one that has a rear facing inlet. You will regret it because of the induction noise.
    Intercooler, the CC Ultimate cooler maybe the better top mounts but again, its fecking noisy when the motor is under load and the boost is getting up there.
    Take it all with a grain of salt. You will be told otherwise in many different ways. So pool it all together and think on it.
    Have fun.
  5. The Following 2 Users Say Thank You to mudski For This Useful Post:
    AB (25th September 2017), JackCollo (26th September 2017)
    587 Post(s)
    You can get a paper filter with the same style to suit the Fatz mate.
    Dec 2016
    Also another thing I need to iron out is weather to go to a 5 speed manual or go with the Wholesale automatics 5 speed auto.
    Or to stay with the zd30 4 speed auto
    469 Post(s)
    Yeah you seen how much they are? Big $$$.
  9. #7
    469 Post(s)
    Quote Originally Posted by JackCollo View Post
    Its 20k for the 5spd auto from Wholesale autos. I inquired about it when I saw them at one of the 4x4 shows. The ZD 4spd auto will be good I guess. A member here used the TCU from a TB45 I think with their TD/ 4spd auto. @jff45 was the man. I want his air box too he made. Lol.
  10. #8
    Dec 2016
    So if I go to keep my 4 speed I need a trans mission control unit and a bell housing adaptor for the td42
  11. #9
    469 Post(s)
    You will need an adaptor yes. I believe you can use the ZD30 TCU. jff45 used a different TCU which made gear changing different, or something like that. Hopefully he sticks his head in and clears it up.
  12. The Following User Says Thank You to mudski For This Useful Post:
    JackCollo (25th September 2017)
  13. #10
    Dec 2016
    I read somewhere that you can’t use the auto zd30 tcu because it uses the throttle position sensor to determine gear changes etc and going from fly by wire to cable you loose the sensor.
