Yes its part of the hub. So it locates the hub centre. The manuals don't have this part. Hence the need to buy the egg ring. You push the egg ring into the wheel hub and thne the locking section has something to locate on. And the step ring is used for the inner gear section to run on as its separate from the out piece of the hub. Unlike the auto's where its all held together when you remove it. Manuals are good but a pain when it comes to wheel bearing servicing as you need to remove the egg ring to get the outer race out.
