Hey guys just thought I'd get some ideas as for which catch can to put on my patrol 2000 ZD30. The brands I've considered have been HPD and flashlube
Any recommendations or words of advice
Cheers jack
Cheers jack
Currently own a ZD30 2000 GU patrol with a dead injector pump about to start a build on a TD42 motor to go in the car and basically rebuild the whole car into a machine of a rig
Hi Jack
There's only one really... Mann Provent 200. Job done!
I got mine from Sydney Filters. They sent it to the UK for me.
Fit a drain tube to the spigot on the underside and run it to where you can get access to drain the unit periodically.
I'd also recommend the provent 200. I have fitted one on mine, really simple drain from the tube at the bottom. Works very well.
A mate installed a HPD on his cruiser, really good quality, but a pain to drain as you have to unscrew the bowl at the bottom.
The provent is also a bit cheaper than the HPD.
Prevent 200 all the way mate, good bit of kit
................on the road
________________________
______ 2017 D-Max _______
Provent 200. Simple, well made, works well.
Where's best place to buy this and the average price?
Pop your location in your profile mate.
Members can point you in the right direction then.
