Results 1 to 10 of 11
Thread: Gq sub belly tank how does it work?
    Aug 2015
    Gday, ive got a gq with what it looks like a aux fuel tank on the drivers side, can someone please tell me how it works, the other day i filled my tabk right to the brim and noticed fuel starting to spill out was this fuel ment to go to the aux tank? Help would be much appreciated
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Lucky bugger having a dual tank on a Q , fuel should not leak at all unless overfilled out the filler neck , should be a switch to pump from sub to main tank but sounds like it might be a back yard conversion that hasn't been finished right .
    Check your dash and see if you have an extra switch that looks new or been added .
    Aug 2015
    Hey mate theres no switch i have read somewhere that it uses a syphon or vacuum type thing but would just like some proper info
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Ok so your two tanks are joined at the bottom , sorry thought it might have been out of a GU .
    Feb 2015
    You might have a leak in a hose or where the sender unit bolts into the top. Often the hose get old and perish
  6. #6
    331 Post(s)
    @Winnie @AB can you guys sort this out. Winnie and AB have both retro fitted sub tanks to the GQ and work well. There will be a pump to pump from the sub to the main tank. Is it petrol or diesel? some of the Petrols had a second pump in the sub and do not transfer but rather suck from one or the other. There should definitely be a switch to either swap the tanks or pump the tanks
  7. #7
    588 Post(s)
    Hey mate the common set up for these is a pump to transfer from your auxiliary to main tank but you said you can't see a switch.
    People can doctor up all kinds of transfer systems so your best bet would be to jump under your car this weekend, take some photos of where the fuel lines go from your auxiliary tank and post it on here for others to check it out.
  8. The Following User Says Thank You to AB For This Useful Post:
    MudRunnerTD (28th April 2017)
  9. #8
    588 Post(s)
    Also as above, whereabouts was fuel coming out?
  10. #9
    Yeah mate if there is no switch jump underneath and follow the pipes. Just see where they go and sit down and try to work out what is supposed to happen. In mine and AB's systems we installed a little pump in between the two tanks to transfer out of the belly tank into the rear tank
  11. #10
    195 Post(s)
    Have a good look where it's spilling from, they often use grey or blue suction hose which can get hard when it's old so doesn't clamp down well on the tank or filler. Same as AB & winnie, have a transfer pump on mine, work's a treat.
    Sent from my SM-T800 using Tapatalk
  12. The Following User Says Thank You to Rossco For This Useful Post:
    AB (28th April 2017)
