6th April 2017, 04:08 PM
#7441
I know what some of you think of 4wd supacenter, but I haven't had an issue with their product only their lack of customer service and delivery times.
Drove down to the lilydale store on Monday and picked up a 2.5 x 2.5 awning, a side wall and a camp cooking stand/plate for $145.
Just fitted the awning and with no problems.
6th April 2017 04:08 PM
6th April 2017, 04:40 PM
#7442
jay see
![](http://www.nissanpatrol.com.au/forums/images/imported/2017/04/41.jpg)
I have a set of their drawers, picked up on gumtree brand new. They went in easy and work great.
I also got the awning and side panel. Took a while to get to W.A. but both look and work as expected.
I have their solar panel in the garage which I haven't tried yet.
It was a cheap way to get started and if I need to upgrade in the future so be it.
The Following User Says Thank You to Mc4by For This Useful Post:
6th April 2017, 04:52 PM
#7443
@jaysee what are the plans for the awning one of those tie in rooms or just a tie in wall??
6th April 2017, 05:05 PM
#7444
Some of their stuff is ok some not so much or needs a tweak or two , I have their drawers which for my GQ were a pita to fit but their new double thumper I recommend , also the awning mozzie mesh tent is good and awning seems just as good as more expensive brands .
Have a bit more stuff from them from ARB and from TJM , disappointed with the latter two more than supercentre .
The Following User Says Thank You to GQtdauto For This Useful Post:
6th April 2017, 05:21 PM
#7445
@GQtdauto I use TJM as I got sick of looking at 4x4s with all the same options
I need to be different, where in n/e Vic are you??
6th April 2017, 05:22 PM
#7446
Ok started the folding solar panel on the GQ today , first work out where the panels will sit bearing in mind I need four 10 litre jerry cans up top at front and a pole carrier and a chainsaw not to mention a bit of room for firewood so this was where they had to go .
Folding panel had to be pulled apart , used a bit of scrap ply under rivets when drilling them out so I didn't damage panel , getting the silicone and mastic off proved a problem also removing the regulator was a half hour job .
All off and cleaned up I tested how it would look and fit .
Now to join the panels I have used silicone , rivets and button screws , had some aluminium angle left over from another job so used it each side and a folding leg from the solar panel to brace , strengthen and join panels together .
Bloody connection boxes were higher than panel edge (see level) which meant a bit more working out but decided to put ali angle on the edge to give clearance .
Once that was done I had a brain wave why not make it adjustable so I can tilt it east or west , then I worked out how to , need to go to town tomorrow for some bits and bobs and will also show photos of what I come up with .
Not sure if all photos will send ok .
6th April 2017, 05:23 PM
#7447
6th April 2017, 05:26 PM
#7448
Will post the other six photos when Puter behaves .
6th April 2017, 05:27 PM
#7449
threedogs
Glenrowan
Three dogs I'm based at good old Glenrowan .
6th April 2017, 05:31 PM
#7450
Doesnt the reg need to be close to a battery???
not far away at all..
