16th January 2017, 10:57 PM
Front LOKKA questions
Looking for unbiased opinions from people who have a LOKKA fitted in the front.
I'm considering purchasing one but would like to know the facts first. It's going in the front of an RB30 turbo with over 300rwkw.
Do they work? Will it handle the power? I've got a heavy right foot, is it more likely to bust cv's? I understand that any locker will cause broken cv's when bouncing off rocks etc but looking for people's experience with them.
Thanks in advance.
16th January 2017 10:57 PM
16th January 2017, 11:23 PM
Depends on what you want to do with the car. When in 2WD you wont know its there so f you are going fast there wont be a problem. If you want to use that power in 4WD high range on dirt roads then don't put the LOKKA in as it does affect the steering. I tends to make the car fidgety and steer from side to side. It's the only drawback that I have encountered with my LOKKA. Everything else has been good so far.
In low range if you are careful with the power it should be fine. I have had mine for 4 years without a problem but I don't have 300 rwkw in my rig. If you want to spin the tyres in 4WD then probably wont be a good option as it will always be on. With a selectable locker it will be switched off most of the time and only switched on for times you will be going slow anyway.
The Following User Says Thank You to Rock Trol For This Useful Post:
RB30Turbo (18th January 2017)
17th January 2017, 01:39 PM
Thanks for your reply Rock Trol.
I never use 4WD when doing high speeds so that shouldn't be an issue.
I'll get one and give it a go I reckon. If it breaks or plays up I'll go an Eaton Harrop electric
17th January 2017, 06:06 PM
The Following 2 Users Say Thank You to growler2058 For This Useful Post:
RB30Turbo (18th January 2017), Rock Trol (18th January 2017)
17th January 2017, 06:09 PM
The Following User Says Thank You to growler2058 For This Useful Post:
17th January 2017, 06:23 PM
I've got one in mine and although its only 118kW engine I'm yet to break it LOL.
There are things to consider though:
Cons:
Really heavy steering once in 4WD mode,
Extreme understeer in the soft stuff so not pleasant to steer precisely and a bit dangerous on over correcting,
Annoying clicking on harder surfaces under full lock, you can't have auto locking hubs,
4WD Systems company is very difficult to deal with indeed I advise you against.....(When you read about history of LOKKA and 4WD Systems you will not be pleased)
Chinese made....
So consider other reputable company like Eaton Lockright or Spartan locker
Pros:
Cheap (not really when you see what is in the box),
Easy to use,
Its there all the time so no guess work as to when to engage or not.
Personally if I had my time again I'd go for proper manually selectable diff locker probably E-Locker as I'm not a fan of ARB.
Regards
RB30Turbo
Thanks in advance.
The Following 2 Users Say Thank You to Rumcajs For This Useful Post:
17th January 2017, 06:34 PM
SPAMINATOR
Rumcajs
Cons:
Chinese made....
Pros:
Easy to use,
Regards
From my experience I didnt experience any of this in my GQ, hopefully its the same when i get one for the GU
This is caused by it unlocking when turning so the steering shouldnt be heavy. If under load and powering on it wont click and will stay lockedAnnoying clicking on harder surfaces under full lock, you can't have auto locking hubs,
![](image.php?u=2058&type=sigpic&dateline=1604048275)
17th January 2017, 07:04 PM
growler2058
Well, my experience is based on sand and on dirt roads. I actually avoid going in 4WD mode on normal dirt roads as the understeer combined with tight rear LSD can make the car twitch and unstable in fast flowing corners because front end wants to plow straight and rear end wants to come out sideways, I nearly rolled the beast several times before I wised up as to what is happening. Definately have to slow down comparing to driving with open front diff.
Steering is way heavier too, and can't really relax the grip on the steering wheel once starting to turn as the tendency is to wrestle the steering wheel out of my hands back to straight ahead so it is uncontrollable to a degree (unlike with castor angle the front wheels will return to centre once starting to straighten...) So after you've been driving in the deep sand for several hours your arms can feel it....
In the deep sand taking sharper corners is a lottery and sometimes counter productive as when I need a momentum and the bloody thing understeers the only way to get it to turn in I have to back off and then....
I'm not complaining as such just telling the experience as is. The understeer behavior is well know with these indeed any front lockable diff.
Also the instructions from 4WD Systems are fraudulent and incomplete as this installation is in all seriousness not just several hours, indeed it is a massive job with so many gotchas and opportunities for the things to go wrong especially for the inexperienced. If you think you can knock it in the afternoon then you are sadly mislead.
Thoughtful preparation is required as chances are that you may as well also repack/grease front wheel bearings (requiring you to change the seals too), possibly re do the CVs etc...change/service brakes etc....
Regards
The Following User Says Thank You to Rumcajs For This Useful Post:
17th January 2017, 08:22 PM
SPAMINATOR
Rumcajs
Regards
Yeah same just my experiences over the 5 years i had the ol Q, but were 100% different than what you describe. Must be the size of car that makes such a difference ay
17th January 2017, 08:25 PM
